Without a remote control; you can't select any functions. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops; and by Online shopping.
SOURCE: my tv is stuck on key lock how do I fix it
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
• Unlock all of the channels on the TV by
entering "6688," which is the factory reset code. This code resets
the TV to original factory settings. Once this is done, you will have to go
through the initial setup.
• Call Omni technical support at (416)
260-0047. A technician can help you troubleshoot the television as the problem
may not be the child lock. You'll need to know the model number and serial
number of the TV.
•Take your television to a TV repair shop if you
are still unable to unlock the TV. The problem may be with the wiring, so the
repairman may have to rewire the TV
