Question about Furniture
How can a RIP of lattice on a dining room chair be fixed? The RIP is along the frame of the chair and it may be 8 inches long. Also another chair has a hole in the lattice. Any ideas where I can bring them?
Posted by Peggy Skoglund on
5 Related Answers
Anonymous
  • 13 Answers
SOURCE: Bobbin tangling
Sounds like the bobbin is spinning to fast or is winded to loose. Try adjusting the tension on the bobbin.
Posted on May 27, 2009
John Morganti
  • 864 Answers
SOURCE: door gasket gap
Apply a small strip of soft foam weatherstripping tape to the frame in the area of the gap.  You may have to taper the ends slightly to match the gasket profile or the foam tape will force the gasket open for a greater length.
Posted on May 30, 2009
wentlanv
Handie Andie
  • 710 Answers
SOURCE: I am having problems getting
Hi Rita,
Yes, the + and - adjusts the depth of the staple. You should check the setting periodically as it has a tendency to move as you handle the stapler.
Also, holding the nose of the staple flush and steady on the surface helps to drive them to the proper depth.
Hope this helps. If it does, I'd appreciate a 4 thumbs up, keeps me working... Thanks,
Handie Andie
Posted on May 08, 2011
master_slim
Mark Oliver
  • 6 Answers
SOURCE: What staples do I purchase for my Stanley TRE500 to staple fabric on dining room chairs?
Stanley Sharpshooter Staples, 3/8 Inch Leg Length, I would say as thay are stonger and deeper.
Hope this help's
Posted on Jul 02, 2012
Stephanie Kerr
  • 28 Answers
SOURCE: What colors does the cover for the HENRIKSDAL dining room chair from Ikea come in?
The cover for this chair comes in a wide variety of colors such as white, lilac, sand and striped light brown.
Posted on Aug 09, 2012
Just bought some dining room chairs and we can't see how to attach the cushions! Is there a secret way of doing it?
By cushions if you mean the seat then all it needs is a few wood screws to fasten to the base. if there is no hole for screws in the base frame then you could fix these with angle brackets.
Aug 24, 2014 | Furniture
Is it ok to use my REIDAR stackable dining room chairs from Ikea outside during the summer around out patio table?
Yes. These chairs are made from aluminum and are therefore permitted to be used outdoors.
Aug 09, 2012 | Furniture
I want to build my own set of dining room chairs. Can someone recommend a good site to use with design templates?
I found you a site with designs for both standard dining room chairs and chairs with arm rests. Hope this helps you out.
http://www.freeww.com/diningchair.html
Hope this help's
Jul 02, 2012 | Electric Stanley Tre500 Staple Gun /...
How much room should I leave between chairs in my kitchen?
In order to make the seating comfortable for your diners,each chair should be at least 20 inches apart. Keep in mind that your guests will need to be able to access their seatand be able to leave without squishing themselves too much. I would say the ideal length between chairsis about 30 inches.
May 29, 2012 | Furniture
What is the right height for a kitchen chair?
There are a few factors the go in to determining the properheight for a kitchen chair. Dining roomtables tend to be about 30 inches tall. Therefore, you don't want your chairs to be more than 18.5 to 20 incheshigh.
Furniture Logo
50 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Furniture Expert? Answer questions, earn points and help others
