SOURCE: On a Samsung GT19000, I
As you said,
> Menu (Home Key) > Applications > Settings > Location and Security > Require Pattern
< Screen Unlock Pattern check box should be selectable or de-selectable. But if this doesn't work, then there's must be something wrong with the system files, like software/o.s corrupted, or some other applications already deactivated or some malwares have infected. It could be Java script problem as well, since almost all the programs/applications/features are running through Java.
The only possible trick you can try is "Phone Reset" but be sure, data saved on your phone will be lost at every reset attempt. There are several reset and all reset codes don't work on all models. I am giving you the most common codes:
Hard Reset Codes:
*2767*688# or *2767*2878#
*2767*JAVA# Java Reset and (Deletes all Java Midlets)
*2767*MEDIA# Reset Media (Deletes All Sounds and Pics)
*2767*WAP# Wap Reset
*2767*CUST# Reset Custom EEPR0M
*2767*FULL# Reset Full EEPR0M (Caution)
For example : *2767*JAVA# would be keyed in as *2767*5282#
Good luck.
Thanks for using FixYa.
SOURCE: samsung galaxy s6102 swipe lock so many patern attampts and my email not open in login phone
volume up and power button until you see the android guy, erase data/factory reset, if this is too plain let me know i will break it down, also let me know if it does not work good luck questions just ask
You got to reset to factory setting you will lose all info thou
SOURCE: cant get the screen password to go back to swipe from pattern
after locking it, and forgetting it there won't be another way to unlock, unless you perform a hard reset.
if you wanna hard reset your phone lookup your manufacturer guide on how to.
for an example i'll attach this link so you have an idea on how to do it. hope i helped.
https://www.verizonwireless.com/support/knowledge-base-104024/
