Question about Adobe Computers & Internet
Why is adobe acrobat not working on my my computer? worked good till now the screen read update completeitdid automatic update?
Posted by Sam J Mandel on
The Spaminator
    Brigadier General:
  • Adobe Master
  • 493 Answers
Suggest if program is acrobat reader to search internet for acrobat reader download and try re-installing it manually
Posted on Jun 01, 2020
5 Related Answers
sandrew
andrew pester
  • 2961 Answers
SOURCE: Adobe Acrobat 6.0
Normally if you click on help at top of menu, then detect and repair normally sorts it out
Posted on Oct 17, 2006
lgc999
'Leslie Carroll
  • 39 Answers
SOURCE: Adobe Acrobat Reader
This is the same software. What type of printing problems are you experiencing?
Posted on Nov 06, 2007
Anonymous
  • 265 Answers
SOURCE: Filling in Adobe Acrobat job applications
Most Acrobat forms (your job application for example) are designed to be printed out and the fields filled in by hand. If you create a new form, based on the job application that you've downloaded, you may be able to type in your information in the fields, but it will depend on the security level of the PDF that was created originally. It sounds like the person who designed the form didn't set it up to accept input, merely to be printed out and filled out manually using the first handheld computer: a pencil.
Hope this will FixYa!!!
Posted on Dec 31, 2007
Anonymous
SOURCE: Can't print from Adobe Acrobat
I was unable to print with adobe as well. I changed the document to print as an image under the advanced tab.
Posted on Jan 17, 2008
Anonymous
SOURCE: Adobe Acrobat 8 error 2711
Sounds menacing but it’s fairly easy to fix.
Heres how to fix it:
  1. Download msicuu2.exe (Windows Install Cleanup Utility) from Microsoft, or by clicking on the file name.
  2. Run msicuu2.exe
  3. You will then get a message asking if you wish to roll back the in progress installation. You do.
  4. Install Adobe Acrobat or Reader 8.
Adobe’s more intrusive way of fixing it:
  1. Click Start>Run, type in regedit then hit enter or press ok.
  2. Back up your registry (not actually mentioned by adobe but a good idea whenever you’re about to make changes to the registry)
  3. Look for Key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Inprogress
    and delete the key if it exists.
Posted on Sep 10, 2008
Adobe Reader on ASUS laptop
PDF Repair Toolbox is a a new Adobe Acrobat file repair tool that allows users to fix PDF files which are inpdfible from Adobe's file recovery. A common error message from Adobie is that Acrobat PDF file format is having difficulties, the file is damaged and could not be repaired by normal means.
https://www.acrobatrepairtoolbox.com/
Jun 21, 2018 | ASUS Computers & Internet
How to Fix Adobe Acrobat Reader
Adobe Acrobat Reader needs to be updated. It sounds like your automatic update is turned off.
Mar 10, 2015 | Adobe Acrobat® 8.0 Standard Full Version...
When opening any pdf file internet explorer gets stop working and browser restart. Reader.exe faulty module
Check for any updates and optional updates in control panel.
Run Windows Update in Windows 7
Using Windows Update in Windows 7 keeps your laptop and desktop computer safer.
Microsoft periodically releases updates and security fixes.
By loading these updates, you are keeping your Windows computer safe from viruses, spyware and malware.
With Windows Update, you have the ability to download updates and choose when to install, automatically have updates applied, check for updates only and/or never check for updates.
Click "Start," "All Program" "Windows Update."
Alternatively, you can click the "Start" orb and type Windows Update in the instant search box.
Windows Update appears in the list for you to choose.
Click "Check for updates;" it is located on the left hand-side of the open window.
Windows 7 begins checking for updates.
They are categorized as important and optional.
Click the "Important Update" link and choose all that apply.
Once you are finished choosing your important updates, click "OK."
Click the "Optional Update" link and choose all that apply.
Click "Install updates."
Windows 7 downloads your updates and installs them.
A reboot of your computer is required once the update process is complete.
You might also try this for IE 7 not sure about IE 9
Fix Adobe Acrobat or Reader 9 Crash on Internet Explorer 7 Problem
Adobe Acrobat and Adobe Reader 9 enable the computer to view PDF files.
These applications also install an add on, or plug in a small software that adds extra features to a programto Internet Explorer 7, enabling IE7 to load PDF files from within the browser.
If conflicting add-ons are installed to the browser, or if the Adobe Acrobat or Adobe Reader software is not properly installed, however, IE7 will crash whenever it attempts to load a PDF.
Open Internet Explorer.
Hold down "Alt" to show all of the toolbars.
Click "Tools" from the menu bar.
Click "Internet Options."
Go to the "Advanced" tab.
Click "Reset" to revert the Internet Explorer 7 settings to default.
Click "OK."
Restart Internet Explorer after resetting the browser.
Return to the "Tools" menu and click "Manage Add-ons."
Wait for all of the add-ons to load in the right pane, then look through the list to find the add-ons labeled "BHO" or "Browser Helper."
Click each add-on with "BHO" or "Browser Helper" in the name, then click "Disable." Restart IE when finished.
Download the Adobe Acrobat or Adobe Reader 9 software from the Adobe website, if you do not already have the setup program on your computer or on disc.
Click "Start."
Click "Control Panel."
Click "Programs," then click "Programs and Features."
Scroll to "Adobe Acrobat" or "Adobe Reader 9."
Right-click the program. Select "Uninstall" from the context menu.
Follow the onscreen directions to remove the software from the computer, then restart the PC.
Log back in to Windows and click "Start."
Click "Computer."
Navigate to the folder where the Adobe setup file is saved or insert the Adobe Acrobat CD.
If the file is saved on the computer, double-click the file to launch the installer.
Follow the onscreen prompts to reinstall the plug-in to Internet Explorer 7.
Restart the PC when the installation is complete.
Open Internet Explorer 7 after booting to Windows.
Open a PDF file from within the browser to test the browser.
http://kb2.adobe.com/cps/331/331025.html
Dec 10, 2013 | Computers & Internet
Turned my system, it alerted me that there was anew update for my Adobe, so I let it download. Now I can't even play a song on myspace or watch a video on youotube. Or anywhere else What happened? adobe 8
you didn't say what OS you are running but in all probability you can roll back the driver by going to a restore point before you downloaded the update. If you for some reason are space saving your hard drive and don't keep restore points I would suggest you remove the program completely including trace files by removing the entire adobe acrobat file and after restarting your computer reinstall the last version that worked for you. good luck
Dec 24, 2009 | Adobe Acrobat® 8.0 Standard Full Version...
Hp 8500 officejet won't print PDF files; word, quickbooks all work fine.
You need to go into Printers/Properties/Advanced
Select checkbok Spool Print Documents. Then it will work.
Sep 17, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
Cannot complete uninstall of adobe acrobat 9 pro.
here is a link from adobe's website, this will help you completely remove the product.
http://kb.adobe.com/selfservice/viewContent.do?externalId=kb400654&sliceId=2
Apr 12, 2009 | HP Pavilion a1410n (ER890AA) PC Desktop
Can't update Acrobat Reader
Go to the following link and you can find the update versions all the way back to 6.0
http://www.filehippo.com/download_adobe_reader/
However the versions after 7.0 are described in the technical specifications tab for each version as not compatible with all Windows OS versions, only Windows 2000/XP/2003/Vista/XP64/Vista64.
It seems you may not be able to update, sorry.
Nov 16, 2008 | Adobe Acrobat 6.0 for PC
Sentry really big universal remote
the following is a link to the updated code list for the RMC-10, note it is in pdf format so if you do not already have adobe acrobat reader you will have to download that before you can read the code list. I will also leave the link to download the adobe acrobat reader in case you need it
Hope this helps
Carl
http://www.sentryindustries.com/pdf/instructions/RMC10_Instructions.pdf
http://www.adobe.com/products/acrobat/readstep2_allversions.html
Feb 07, 2008 | Televison & Video
Reading files
hi,uou can download the latest version of acrobat reader from this link
http://www.adobe.com/products/acrobat/readstep2.html
if you want the adobe 5 click this link
www.brothersoft.com/downloads/adobe-acrobat-reader-5.html
Dec 17, 2007 | Adobe Acrobat 6.0 Professional for PC
Adobe reader
i order to update the adobe acrobat reder run the set up it will automatically detects the old version and asks for update or uninstallation of old version follow the steps and ull get it installed after that if the setup did not detect the old version on ur computer then the existing version on ur computer is not installed properly or there is no any acrobat reder software in ur computer
Nov 21, 2007 | Adobe Acrobat 7.0 for PC
Computers & Internet Logo
Top Adobe Computers & Internet Experts
Jane
Level 1 Expert
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
