Question about Pool & Spa
Backwashing/Filter help! Pool filter is at 0 PSI and heat not turning on now. What am I doing wrong?
Posted by miranda kawula on
5 Related Answers
Anonymous
  • 33 Answers
SOURCE: What is normal pressure at pool sand filter when pump is running?
This is normal pressure! As the filter becomes more dirty you will see the pressure get higher 15/20 it's time to backwash!
Posted on Jan 27, 2009
jgwhomeequip
Jeremy Reddick
  • 1902 Answers
SOURCE: sand filter problem
The pump is to big for the pool. So with that being said it is asking you to back wash more then you should need to because it is pulling water at a much higher rate then what your pool is actually calling for. I would recommend taking it down to a 700gl and this would solve your problem. Also you can replace the drain lines and suction lines to smaller lines and that will also take care of the issue at hand but I do not recommend that at all
Posted on May 27, 2009
Anonymous
  • 4 Answers
SOURCE: what is the normal psi on a haward sand filter
i was told that between 9 to 12 psi is normal on all pool pumps.
Posted on Jun 29, 2009
David Shaub
  • 2976 Answers
SOURCE: Do I need a new sand filter psi gauge?
It wouldn't hurt to replace the gauge every few years, since it makes contact with heavily chlorinated water. They are available for less than $10.
Posted on Jul 07, 2009
Anonymous
  • 139 Answers
SOURCE: Filter clicks, but won't turn on. Pool lights
put your aqualink into service mode. then select components manually this will override any pre-programmed options
Posted on Jul 21, 2009
I put my Hayward ST180T on rinse to vacuum the pool and I ended up with sand in the pool what happen?
You are using the wrong setting to vacuum. This type of pool filter should be set to "filter" for normal vacuuming or to "waste" for heavy loads. The "rinse" setting makes sure that all of the dirty water is out of your filter after backwashing.
Jul 14, 2011 | Hayward SAND FILTER, PRO SERIES
After vacuuming and backwashing, the dirt recycles back into the pool PSI is only 8 - what is wrong?
Assure that the o ring is positioned onto the multi-port throat correctly. That could cause dirt to recycle into the pool water.It could also be issues with the multiport valve in the pool filters.
Jul 28, 2010 | Waterway Clear Water 22" Sand Filter...
After I vacuum the pool, backwash it and then turn the filter system back on it blows in a lot of green water back into the pool. What should I do?
1st Green water is algee. Kill the algee in the pool. 2nd when you're finished backwashing the filter. Stop pump and move valve handle to rinse position. Then restart pump. Run in rinse mode until glass is clear. Then stop pump again, and move lever to filter position. When you're backwashing, you're reversing the flow of the water through the filter. When you switch directly back to filter, anything left loose in the filter flows back to the pool. When you select rinse, it reverses the flow back to normal, but keeps the water going to the waste outlet until clear, that way that green puff of water will go out the drain. You can get complete manuals from www.haywardnet.com
Jul 20, 2010 | Hayward SAND FILTER, PRO SERIES
De filter pressure too high water is cloudy
backwash the filter from main drain until sight glass is clear-this will reduce filter pressure. After backwashing return gate valve to filter position, then filter from main drain only. check water chemistry. add a clarifier to water
Jul 28, 2009 | Pentair 3/4HP Pinnacle High Performance...
Pressure at 15 psi after backwashing
No that is normal pressure, when the pressure rises more than 10 psi over that in a 24 hour time, you should backwash the filter. Hope this helps
Jul 13, 2009 | Home
Sand filter not catching little debris
Filter is being bypassed at backwash valve, due to poor spider gasket in valve, or there is a broken lateral in bottom of sand filter, causing debris to return to pool..
Feb 18, 2009 | Hayward Pro Series 18" Above Ground Pool...
Pool & Spa Logo
48 people viewed this question
Top Pool & Spa Experts
john h
David Spradling
David Spradling
rogerpaul3
Level 1 Expert
Are you a Pool and Spa Expert? Answer questions, earn points and help others
