Won't work, even though it's a 10ga., it won't take the pressures of a rifle caliber and the firing pin is too big. H&R will re-barrel a shotgun to another shotgun gauge or a handgun caliber. They will re-barrel a rifle to a shotgun gauge, a handgun caliber or another rifle caliber. You have to send it back to them to be fitted, they won't just sell you the barrel.
MAXIMUM LOAD WARNING
45 and 50 CALIBER RIFLE:
45 Caliber Pellets come in one size: 50 grain
50 Caliber Pellets come in two (2) sizes:
50 grain volume equivalent which equals 50 grains of loose powder by volume.
30 grain volume equivalent which equals 30 grains of loose powder by volume.
The maximum load per shot should never exceed total Pellets containing more than 100 grains volume equivalent. That means, no more than:
45 Caliber 1) Two (2) 50 grain Pellets
2) Three (3) 44/45 caliber 30 grain
50 Caliber 1) Three (3) 30 grain Pellets, or
2) Two (2) 50 grain Pellets, or
3) One (1) 50 grain Pellet and one (1) 30 grain Pellet
54 CALIBER RIFLE:
54 Caliber Pyrodex Pellets come in one size only:
60 grain volume equivalent which equals 60 grains of loose powder by volume.
The maximum load per shot should never exceed 120 grains (2) Pellets.
Winchester 1876 .45-60 (W5880)
Winchester 1876 .45-60 caliber rifle. Made in 1883. Unusual gun as it has a half round half octagon barrel which is something you rarely find on a 1876. Gun is excellent with approximately 97% of the original finish. Wood is...
Winchester 1876 .45-75 (W2960)
Winchester 1876 .45-75 caliber rifle in 35xxx serial number range with 95% blue overall and excellent wood. Has a tiny T.J.H. on receiver. This is a top condition '76 with factory letter.
Winchester 1876 .45-75 (W3037)
Winchester 1876 .45-75 caliber rifle with very good wood and metal. Rare 7 leaf sight called for in factory letter. Rare 7 leaf sights are found on some 73's but not mentioned in the factory letter.
Could use more info, such as markings on the barrel and or breach. The Remington rolling block type single shot goes back to the 1860'S. The first 22 calibers around 1888. The rolling block went through 8 changes. The different types or changes are where various pins and screws are located, size and shape of hammers and triggers. The New Model Number 4, made from 1890 - 1933 came standard in 22 cal. with a 22 1/2 inch Oct. barrel. It will have a small lever on the right side of the breach. Approx 50,000 of these where made between the years noted. You could very well have a model 1, 2 or a model 7, which will be rare if in very good shape as only 1000, No. 7's where made. Tracking the serial number will be hard unless you contact Remington.
If the trigger is adjustable set it more coarse to hook the piston rod. Make sure trigger is loose and will reset to it foremost position. Check trigger spring and pin for ease op operation. Lastly check if piston rod did not turn inside cylinder so hook is turned away from trigger.
