Question about Pool & Spa
What pump do I need for a Coleman maxx spa model 471dsm
Posted by Michael Beck on
1 Related Answer
Anonymous
  • 8 Answers
SOURCE: Coleman 500 series SPA 50A circuit breaker trips
bad connection follow wires from breaker to to moter theres abreak causing arc find it
Posted on May 09, 2010
Parts. i have a 408 seaspray model and the seal kit is bad. I need a replacement, but am having difficulty finding one. Does Coleman have the part for sale?
The XP2 pump uses a 5/8" shaft seal.
You can find them as under part numbers - PS-200, AS-200 or 92500150.
Feb 27, 2012 | Pool & Spa
May 08, 2010 | Pool & Spa
I bought a home and my coleman spa 400 series has a problem, the jets 1 don't come on, jets 2 do. the water isn't heating up. was wondering what the problem could be
Pump one is the pump that does all the work in your spa. It handles the heating and filtering. If pump one does not work, It will not heat. It is likely pump one is gone but a technician would be needed to determine if it is the pump or the spa pack.
Dec 23, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
I have a coleman spa about 4 years old that is leaking, should this be repaired by a plumber or would it take a spa repair person. it is a 6 to 7 person tub coleman horizion
this has to do with where the water is coming from.
1. wall fittitng. just remove it, reseal and replace
2. pump leaking, usually means shaft seal.
3. plumbing fitting. usually just replace the fitting.
4. fiberglass cracked. get a boat repair man and have him fix it. these guys are usually pretty good.
David
May 18, 2009 | Pool & Spa
Pool & Spa Logo
42 people viewed this question
Top Pool & Spa Experts
john h
David Spradling
David Spradling
rogerpaul3
Level 1 Expert
Are you a Pool and Spa Expert? Answer questions, earn points and help others
