This Error 1702 problem can occur if all the following conditions are true:
Because the files in an administrative installation are uncompressed, and the files on an Office CD-ROM are compressed, the Windows Installer cannot resolve the differences between the two source types.
The resolution to this problem depends on whether you can obtain access to a network administrative installation. Use the following methods, as appropriate to your situation.
If the original administrative installation from which you installed Office is not available, you can use a different administrative installation for the Office source file location. To do this, follow these steps:
OK
new network path\Setup.exe /fvm package name.msi
where new network path is the full path to the alternative network administrative installation, and
package name is the name of the Windows Installer .msi package on the root of this administrative installation (for example, Proplus.msi).
SOURCE: navigation fatal error Error 1706
Heres what microsoft says about 1603
http://support.microsoft.com/default.aspx?scid=kb;en-us;834484
CAUSE
loadTOCNode(1, 'cause');
You may receive this error message if any one of the following conditions is true:
The folder that you are trying to install the Windows Installer package to is encrypted.
The drive that contains the folder that you are trying to install the Windows Installer package to is accessed as a substitute drive.
The SYSTEM account does not have Full Control permissions on the folder that you are trying to install the Windows Installer package to. You notice the error message because the Windows Installer service uses the SYSTEM account to install software.
RESOLUTION
loadTOCNode(1, 'resolution');
To resolve this problem, do any one of the following, depending on the cause of the problem:
Install the package to a folder that is not encrypted.
Use this method if you receive the error message because you try to install the Windows Installer package to a folder that is encrypted.
Install the package to a drive that is not accessed as a substitute drive.
Use this method if you receive the error message because the drive that contains the folder that you try to install the Windows Installer package to is accessed as a substitute drive.
Grant Full Control permissions to the SYSTEM account. (for Windows 2000 and Windows XP only)
Use this method if you receive the error message because the SYSTEM account does not have Full Control permissions on the folder that you try to install the Windows Installer package to.
To grant Full Control permissions to the SYSTEM account, follow these steps:
1.
On the Windows desktop, double-click My Computer. The My Computer window appears.
2.
Right-click the drive that you want to install the Windows Installer package to, and then click Properties.
3.
Click the Security tab.
4.
On the Security tab, do the following:
If you are using Microsoft Windows 2000, verify that the Name box contains the SYSTEM user account.
If you are using Microsoft Windows XP, verify that the Group or user names box contains the SYSTEM user account.If the SYSTEM user account does not appear in the box, follow these steps to add the SYSTEM account to the box:
a.
Click Add. The Select Users or Groups dialog box appears.
b.
In the Name field, click SYSTEM, and then click Add.
c.
Click OK.
5.
In the Permissions section, click to select the Full Control check box under Allow, and then click Advanced.
6.
Do the following:
If you are using Windows XP, in the dialog box that appears, click to select the Replace permission entries on all child objects with entries shown here that apply to child objects check box for the SYSTEM account, and then click OK.
If you are not using Windows XP, in the dialog box that appears, click to select the Reset permissions on all child objects and enable propagation of inheritable permissions check box for the SYSTEM account, and then click OK.Note If you receive a security message, click Yes.
7.
Wait for the operating system to apply the permissions that you have selected to all child folders.
8.
Run the Windows Installer package.
SOURCE: Navigation fatal error Error 1706
yes..I saw that..need teh model number of the actual gps you are using, please..
SOURCE: HP Photosmart D7460 Error Message
Using an administrator account, remove HP Smart Web Printing using Control Panel - Add/Remove Programs.
If required, download and install HP Smart Web Printing from http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&softwareitem=dj-56929-4&os=228&product=3551212&
(Thanks to Bellbird at http://forums.pcworld.co.nz/archive/index.php/t-91677.html).
SOURCE: Hi, when I start my IBM laptop I received an
as per my experince
I suspect your problem is related to the fact that you are loading
software on CD-ROMs from a DVD drive and XP is having problems
locating the drivers but the fix isn't simple.
Microsoft says that Error 1706 is a Microsoft Office Error code which
indicates that required files can not be found by Setup. Since you
are trying to install new programs I feel that this is probably the
correct interpretation of your error code.
Microsoft's Knowledge Base Article 297834,
http://support.microsoft.com/default.aspx?scid=kb;EN-US;297834
seems you forgot to say upgrade word.
not fresh installed.
if you fresh install then there is no such thing. PP12.
nor what OS is there now w8? w7
the installer knows there is no PP12 support for W10 and stops, that tells you to
1: remove PP12
2; or do fresh install (always best) are you backed up your data, also not told this.
well remove Paperport 12.
first.
then w10 be happy.
the real problem is that you failed to ask HP.com for support on w10, and for a fact there is no HP support on w10 for THIS PC,!! fact.
same as mine too, but have w10 on mine after
disabling many failed things on said PC.
all finger print readers first.
windows 8 is max on this PC officially via HP.com
on mine the hDD drop protectors software is dead too. so put in SSD and disabled that device in the BIOS.
there is more dead things in the device manager too, but all are useless to me.
I have sound and ethernet and wifi working w10
0n mine. not advanced security toys.all are dead .
w10 can be forces on this PC just takes lots of hard work, ok? are you up to work?
you can sometimes force w8 drivers on to W10
but I will not cover that here, in fixya
but google this.
loading w8 drivers to w10 in compatibility mode.?
bingo, vast vast examples, even microsoft.com tells you how.
upgrades are very hard, if lots of apps loaded that do no support w10, ! or hardware.
