Question about Samsung Televison & Video
I have a Samsung UN46D6003SF tv it will come one when I plug it in and show smart TV logo then go to blank screen. It will not respond to remote or buttons on TV. What has went wrong so I can order and replace. Thanks for any suggestions
Posted by Daniel Cox on
ray gallant
    Top Expert:
  • Samsung Master
  • 67,926 Answers
WE ARE NOT A LOCAL TV REPAIR SHOP SORRY
Posted on May 23, 2020
5 Related Answers
Anonymous
  • 104 Answers
SOURCE: Citizen house tv that has a 'lock' logo on screen
The TV has been 'Locked'. To unlock it press the DISP button for 4 seconds. Since you have a universal remote and there is no way to determine which button is the DISP button try holding each button on the universal remote for 4 seconds until, hopefully, you find the correct one.
Posted on Mar 11, 2008
Jim Krause
  • 1779 Answers
SOURCE: JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
Posted on Feb 04, 2009
Anonymous
SOURCE: We just purcased Toshiba 26AV502U, now the screen is blank
Heard back from Toshiba. They said to unplug the TV, wait at least 3 minutes, and then plug it back in. This should allow it to reset itself. Sounded too simple, but after doing just that the tv has worked fine for the last three days! Toshiba noted that if this didn't resolve the problem we should contact them to have a Toshiba Authorized service person come check out the tv. It worked for us, hopefully it'll work for you too. Good Luck
Posted on Apr 25, 2009
Anonymous
Hi , I have the same problem with my LT-42X688,so i called the service of my extended warranty provider . the TV technician just left and told me the motherboard is the problem. he said its the third one this week he has seen with the same symptoms. he ordered the motherboard and i've got to wait 5 to 7 work days before the part will be in . I will keep you posted when the guy will return.
Posted on Jul 21, 2009
davidwkushne
  • 71 Answers
SOURCE: screen went blank, cannot get TV to respond. turns
CAPACITOR C208 BAD 680UF 16V ON POWER SUPPLY BOARD.
Credit to: http://www.repairworld.com/
Posted on Dec 27, 2010
Which board would cause no picture on Samsung UN55H7150AFXZA TV and need to be replaced?
Hi Chris,
From what you have mentioned about your TV it appears to be a bad mainboard causing the problem.
May 10, 2018 | Samsung Televison & Video
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
Led tv
is this on all source/input selections?
Apr 22, 2014 | Samsung BN94-05429D Main Board...
Samsung smart tv manual
Sadly only the Manufacturer can tell you the answer to your problem they created
Jan 02, 2018 | Televison & Video
Auria eq2288f 22" lcd tv
What has happened is that one or more of the back light tubes were broken in shipping, AURIA used hard foam packing and the TV could not handle the shock of shipping because of BAD PACKING from AURIA. if you call customer support they will tell you that is a power supply or inverter issue but it's not it's a broken bulb, you know they know about it because they will not tell you one or the other. if you open the Samsung screen (LTA400HM01) you will see that the bottom back light bulb is broken, why AURIA will not address this issue is beyond me. don't waste you time or money on power supply or inverter boards before you look at the back light bulbs.
Jan 19, 2011 | Televison & Video
Showing blank screen showing no signal on the screen
The Remote needs to be replaced with the same remote or a universal remote the diodes on the inside of the remote will be dirty or worn most case it will be worn. if the remote/tv is not that old then i would take it back to your retailer
Jun 03, 2010 | Haier HLTDC19 TV
Televison & Video Logo
Muntejaya Ginting
Muntejaya Ginting
Ekse
