Question about The Office Equipment & Supplies
One of the bearings and its support ring broke on a SH1418PO shredder. How do I order a full set of 4 bearings?
Posted by Luc Martini on
yadvendra verma
    Habit-Forming:
  • 38 Answers
You are probably missing an insulating ring / washer that goes between your bearing and your armature (the shaft on the center part of the electrical motor. The fact that it does not have a grounded plug is not necessarily an indicator of age or safety so don't be too afraid. DeWalt still uses two prong cords to this day. In these tools they offer what is called double insulation, simply non-conductive material that separates electrical components from the user. The part number for the insulating ring is 681623-9. If you ever wanted to ground the tool you don't really need any special switches you just have to attach the grounding line to the metal casing.
Posted on May 22, 2020
Testimonial: "There is nothing wrong with the motor. that thing is built like a brick s---thouse. The problem is the bearings that support the CUTTER WHEELS."
Staples SPL QW1200 shredder - how to disassemble it to get full access to blades?
remove the bin, remove thr screws that hold the bottom on (to get the cord free) then flip it over so its sitting on top remove the screws around the side walls to the top and remove the top shredder. with the shredder still up side down there are 8 screws around the outside edge (in the 1/4 holes) remove those and you can seprate the housing from the blades and motor. in the one i have the blades in the center are bent and the guides are broke i am looking for replacement parts or another for spare parts good luck i am a automotive tech, and i hate to throw things out just because ond small small part is broke but the hardest thing is finding parts. we live in a world where we are in couraged to reclye but we throw so much away because it is almost imposible to find parts or when you do the replacment parts cost more than a new one. sorry for the rant but i like to see people trying to fix things
Sep 09, 2012 | Office Equipment & Supplies
HI,I NEED PARTS FOR MY SHREDDER SPL-616X. GEAR WHEEL WERE TO GET PARTS
i have the gears - my shredder has broken plastic guides but the gears look fine. i'll mail them to you if you like. Jeff
Aug 22, 2010 | Staples SPL616X Cross-Cut Shredder
I have a Porter Cable 352VS Type 4 sander needs bearings.
You need special pullers for these, you will have to take it to a power tool repair shop.
Jan 26, 2010 | Porter Cable 3" x 21" Electronic Variable...
How do you get the rear u-joint out of the drive shaft on 2005 chevy avalanche
It will need to be pressed out.
Universal Joint: Service and Repair
Nylon Injected Ring
Universal Joint Replacement - Nylon Injected Ring
^ Tools Required
- J 9522-3 U Joint Bearing Separator
- J 9522-5 U Joint Bearing Spacer Remover
Disassembly Procedure
Notice: Never clamp propeller shaft tubing in a vise. Clamping could dent or deform the tube causing an imbalance or unsafe condition. Always
clamp on one of the yokes and support the shaft horizontally. Avoid damaging the slip yoke sealing surface. Nicks may damage the bushing or cut
the lip seal.
1. Support the propeller shaft in a line horizontal with the table of a press.
2. Mark the propeller shaft as to which end is the transmission end and which end goes to the rear axle.
3. Place the universal joint so that the lower ear of the yoke is supported on a 30 mm (1 1/8 inch) socket.
4. In order to shear the plastic retaining ring on the bearing cup, place J 9522-3 on the open horizontal bearing cups. Press the lower bearing cup out
of the yoke ear.
5. If you do not completely remove the bearing cup, lift the cross and insert J 9522-5 between the seal and the bearing cup you are removing.
Continue to press the bearing cup out of the yoke.
6. Rotate the propeller shaft. Press the opposite bearing cup out of the yoke.
7. Mark the orientation of the slip yoke to the tube for proper reassembly.
8. Remove the cross from the yoke.
9. Remove the remaining universal joint parts from the yoke. If you are replacing the front universal joint, remove the bearing cups in the slip yoke
in the same manner.
10. Inspect the retaining ring grooves for plastic.
11. Inspect the bearing cup bores in the yoke ears for burrs or imperfections.
12. Clean the remains of the sheared plastic bearing retainers from the grooves in the yoke.
13. The sheared plastic may prevent the bearing cups from pressing into place and thus prevent the bearing retainers from properly seating.
Assembly Procedure
1. Remove the bearing cups from the universal joint.
2. Assemble 1 bearing cup part way into 1 side of the yoke.
3. Turn the yoke ear toward the bottom.
4. Assemble the cross into the yoke so the trunnion seats freely into the bearing cup.
5. With the trunnion seated in the bearing cup, press the bearing cup into the yoke until the bearing cup is flush with the yoke ear.
6. Assemble the opposite bearing cup part way into the yoke ear.
7. Ensure that the trunnions start straight and true into both bearing cups.
8. Press the opposite bearing cup into the yoke ear while working the cross all the time in order to inspect for a free unbinding movement of the
trunnions in the bearing cups.
Important: If there seems to be a hang-up or binding, stop pressing, and inspect the needle bearings for misalignment in the bearing cup.
9. Press the bearing cup into the yoke until the bearing retainer groove clears the inside of the yoke.
10. Assemble the bearing retainer in the retainer groove.
11. Continue pressing until you can snap both retainers into place.
12. If seating the retainer is difficult, spring the yoke slightly with a firm blow from a dead blow hammer.
13. It may be necessary to lubricate the snap ring with a slight amount of chassis grease so the snap ring seats in the bearing cup groove.
External Snap Ring
Universal Joint Replacement - External Snap Ring
^ Tools Required
- J. 9522-3 U-Joint Bearing Separator
- J 9522-5 U-Joint Bearing Spacer Remover
the lip seal.
2. Mark the propeller shaft in order to show which end connects to the transmission and which end goes to the rear axle.
3. Disassemble the snap rings by pinching the ends together with a pair of pliers.
4. If the ring does not readily snap out of the groove in the yoke, tap the end of the cup lightly in order to relieve the pressure from the ring.
5. Place the universal joint so that the lower ear of the yoke is supported on a 30 mm (1-1/8 inch) hex head socket or a 27 mm (1-1/16 inch) socket.
6. Place J 9522-3 on the open horizontal bearing cups. Press the lower bearing cup out of the yoke ear.
7. If you do not completely remove the bearing cup, lift the cross and insert J 9522-5 between the seal and the bearing cup you are removing.
Continue pressing the bearing cup out of the yoke.
8. Rotate the propeller shaft. Press the opposite bearing cup out of the yoke.
9. Mark the orientation of the slip yoke to the tube for proper reassembly.
10. Remove the cross from the yoke.
11. Remove the remaining universal joint parts from the yoke.
12. If you are replacing the front universal joint, remove the bearing cups in the slip yoke in the same manner.
13. Inspect the retaining ring grooves for dirt, corrosion, or pieces of the old ring.
14. Inspect the bearing cup bores for burrs or imperfections.
15. Clean the retaining ring grooves. Corrosion, dirt, rust, or pieces of the old retaining ring may prevent the bearing cups from pressing into place o
Assembly Procedure
2. Assemble 1 bearing cup part way into 1 side of the yoke. Turn the yoke ear toward the bottom.
3. Assemble the cross into the yoke so that the trunnion seats freely into the bearing cup.
4. With the trunnion seated in the bearing cup, press the bearing cup into the yoke until the bearing cup is flush with the yoke ear.
5. Install the opposite bearing cup part way into the yoke ear.
6. Ensure that the trunnions start straight and true into both bearing cups.
7. Press the opposite bearing cup into the yoke ear while working the cross all the time in order to inspect for free unbinding movement of the
Important: If there seems to be a hang up or binding, stop pressing. Inspect the needle bearings for misalignment in the bearing cup.
8. Press the bearing cup into the yoke until the bearing cup retainer groove is visible over the top of the bearing cup.
9. Assemble the bearing retainer in the retainer groove.
10. Continue pressing until both retainers can be snapped into place.
11. If the retainer is difficult to seat, the yoke can be sprung slightly with a firm blow from a dead blow hammer.
12. It may be necessary to lubricate the snap ring with a slight amount of chassis grease so that the snap ring seats in the bearing cup groove.
Oct 30, 2009 | 2005 Chevrolet Avalanche
Blazer one hub not engaging..suggestions?
Sounds like the spring broke and someone didn't get the bearings tight or lock the nut that tightens the bearings.Its farly easy to do. So jack up the tire.Remove the locking hub and see if it is tight..Make sure when tightening the bearing its ONLY enough to get the slop out of the wiggle which you indicated about it being really loose.Theres also a snap ring that keeps the axle in the locking hub.If any I have indicated is not in there go to your local parts store and they pull up a scmatic and then you can get what you are missing and the order in which the parts go..
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Mar 28, 2009 | 1992 Chevrolet C1500
Where do I get a gear to turn the shredder
Her
Date: Thu, 9 Jul 2009 11:16:33 -0400
Subject: TS4500 from Winsource Ind.
To:
Rick,
This TS4500 shredder had been discontinued for more than 5 years. The factory did not make any spare parts for this model.
Thanks,
Victor
Customer service
e is my response
Mar 22, 2009 | Tech Solution TS-4500 Shredder
Power transformer broke
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Jan 05, 2009 | Tech Solution TS-4500 Shredder
Paper shredder
intimus 14.90 has te drive gear bearing busted how do i change the bearing
Sep 27, 2008 | Intimus 14.90 1/4 Inch StripCut and...
20 people viewed this question
Top The Office Equipment & Supplies Experts
Keith Love
James Cagle
James Cagle
Peter March
Peter March
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
