Bonjour le tuyau devacuation du climatiseur uberhaus modele 87795001 est brise. Est-ce qu'on peut le remplacer.
Posted by sebastien alarie on
Reggie Brown
  • 1,268 Answers
Yes it can be replaced and repaired too you would have to call a person that fixes air conditioners then to have a look and see if it can be repaired or not. It would be more easier to buy a new air conditioner than to repair the one that you have then currently.
Posted on May 22, 2020
Terry
  • Computers & ... Master
  • 11,120 Answers
Telephone en manuel 1-866-206-0888
https://contal.mecanair.net/transfert_fichiers/F151079.pdf
https://contal.mecanair.net/mecanair/st/i2reppiecepub.asp?id1=&ki20586=1&langue=A&ki20503=38&ki20504=109&ki20500=56619&ki20503ori=38
5 Related Answers
Anonymous
  • 94 Answers
SOURCE: flash disk 2G type kingston
are u gujju
just format and get it done
Posted on Aug 12, 2008
Anonymous
SOURCE: probleme avec bluetooth
where i can find my bluetooth driver for my hp pavilion dv4ooo
Posted on Aug 15, 2008
Anonymous
  • 11 Answers
SOURCE: drivers pour le chip CS4180-CM pour win98 fe carte m?re kzm-6120
Vous pouvez trouver les drivers pour:
Cirrus oficial site
Je suppose que vous avez utilisé les drivers du CS4281
Alternative download
Posted on May 04, 2009
c1apton15
Mical Caterina
  • 3400 Answers
SOURCE: le premier probleme c 'est
Sorry I don't understand French but try here -> http://www.landroverresource.com/
Posted on Feb 28, 2011
reggieguia
Reginald Villodres
  • 329 Answers
SOURCE: bonjour, je nai pas de son sur mon pc la carte
GoodDay!
Try to go to this site: www.matsonic.com
Thanks and Godbless!
Posted on Mar 28, 2011
Besopin du code pour manette universelle philips
If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 19, 2013 | Jasco 24911 Remote Control
Ne trouve pas le pilote du dvd ram gt 31n le mien ne fonctionne plus
QUESTION: "can not find the driver dvd ram gt 31n mine no longer works"
Salut.
Il n'est pas clair ce que vous entendez par "DVD-RAM 31n GT." J'ai fait des recherches de ce numéro de modèle "GT 31n", sans succès. Je vais donc supposer que c'est le numéro de modèle du lecteur de disque optique interne (DVD-RAM) de votre ordinateur.
Vous ne dites pas quel système d'exploitation que vous utilisez. Vous avez également choisi de ne pas donner toutes les informations concernant votre ordinateur ou de ses spécifications. Ces aurait pu avoir été des éléments d'information utiles.
Presque chaque système d'exploitation informatique, en particulier les courants, ne nécessite aucun pilote supplémentaire pour les lecteurs optiques comme celle du lecteur DVD-RAM. Les pilotes pour fonctionner presque chaque lecteur optique sont déjà intégrés dans le système d'exploitation.
Le seul logiciel que vous pouvez télécharger pour ce lecteur optique est Firmware. Firmware améliore et renforce les spécifications de performance, mais on peut rarement réparer les défauts ou restaurer un disque optique non-fonctionnement d'une fonctionnalité normale avec Firmware.
Vérifiez l'étiquette pour le fabricant du lecteur. Il est susceptible d'avoir été fabriqué par l'une des entreprises connues pour ce produit (LG, Sony, Hitachi, Samsung, etc.) Allez sur le site Support et Téléchargements de cette entreprise et vérifiez les mises à jour du Firmware associés à ce lecteur optique et de votre système d'exploitation.
Je suis presque certain que peu importe où vous regardez, vous ne trouverez pas de pilotes pour ce périphérique.
Si l'appareil ne fonctionne pas il pourrait être un problème de Jumper Settings. Regardez à l'arrière du lecteur pour voir le Jumper Pins et le Jumper. Regardez sur l'étiquette pour voir un diagramme des paramètres différents pôles.
Si il est toujours défectueux, essayez de le connecter avec un autre câble IDE, et essayez de nettoyer la lentille laser avec un Nettoyeur de CD DVD Lens.
Si il est lente, c'est peut être un problème avec l'ordinateur. Certains systèmes d'exploitation va automatiquement ralentir un lecteur optique à une faible vitesse de base après il a démontré un certain nombre d'erreurs de lecture.
Aussi essayez de vérifier et modifier les paramètres (SATA /) IDE dans le BIOS.
Enfin, le lecteur peut aussi être défectueux et peut-être a besoin d'être remplacé.
J'espère que cela aide.
Si cette réponse va certaine manière à aider à résoudre votre requête, un problème ou de défaut, s'il vous plaît prendre le temps de l'évaluer.
Cela permet aux fournisseurs de solutions, comme moi, mieux comprendre les besoins et le point de vue des questionneurs, comme vous, et nous guide dans l'exploration des meilleures façons de fournir les réponses les plus complets de qualité, utiles et de haute et de solutions que nous pouvons.
Si vous avez besoin d'aide, s'il vous plaît n'hésitez pas à poster une autre question ou ajouter un commentaire à cette question.
Merci pour avoir utilisé FixYa.
Sep 15, 2011 | Computers & Internet
Le son des hauts parleurs ne fonctionnent plus etc,est un modele de logitech ls21
Bonjour bouscotte
Je les testerais d' abord sur un autre pc pour voir si le mal vient bien des HP . Si oui , ne connaissant le modèle par coeur , je suppose qu' il y a un sub . Vérifie s' il n' y a pas un fusible de sécurité et vois s' il est toujours intact . Les connections sont à contrôler .
Après cela , je ne vois qu' une panne de l' ampli dans le sub mais c' est peu probable . Je pense plutôt à un disfonctionnement de la carte son ou bien le son est coupé accidentellement . Clique sur l' icone du hp dans la barre des tâches en bas à droite de l' écran et vois ce qui se passe dans le mélangeur . Si tout est normal à cet endroit , il ne reste plus que la carte son . Vérifie le pilote via le gestionnaire des périphériques . Remplacer la carte son , si nécessaire , ne coûte pas cher .
Bon courage ,
fanaudi .
Mar 25, 2011 | Audio Players & Recorders
I have a telecommande URC-4605B01 I d ont now how to programme my tv is a toshiba tank you i am from canada i read more in french but it ok in englis tank you
Salut et bienvenue a fixya.
Je peut (peut-etre) t`aider avec ce probleme mais j`aurais quelque questions auparavant;
As tu le livre ou liste de codes disponible pour ton URC-4605 ?
Toshiba est une marque tres populaire et a peu pres toute les telecommandes universel peuvent les opere.
Sauf dans certain cas comme; si ta television est un modele combine dvd our vcr ?
Tu peut aussi faire une recherche de code, voici la procedure avec ton televiseur allume.
1. presse le bouton "tv"
2. presse le bouton "setup" et tiend le jusqu`a temp que la lumiere cligne 2 fois.
3. Pointe la telecommande envers la tv et alterne entre les boutons "power" et "tv" jusqu`a ce que la tele s`eteigne.
note: si tu vas trop vite tu peut depasser le code et tu auras a recommencer, tu doit aussi avoir de la patience car tu peut avoir a presser ces 2 boutons une cinquantaine de fois ou plus.
4.Quand la tele s`eteindra tu doit mettre le code en memoire en pressant le bouton "setup" a nouveau jusqu`a ce qu`il cligne deux fois.
J`espere que ca te sera utile .
Salut et ALP
Mar 20, 2011 | Televison & Video
Message d'erreur oooofeoo comment l'enlever faut il changer la batterie
Vous pouvez essayer de le réinitialiser en appuyant sur tous les boutons sauf le pouvoir et les boutons directionnels alors qu'il est allumé. Cependant, ce n'est que temporaire. Plus que probable que vous devrez faire réparer. Le code 0000FE00 signifie qu'il a du mal à communiquer avec la puce NAND. Si tel est le cas, la puce NAND pourrait être absent, il peut être rompu trace, ou votre CLK a court-circuité, donc changer la batterie peut ne pas suffire. Mais si vous voulez remplacer la batterie, suivez les 2 images ci-dessous. Je m'excuse d'avance pour toute erreur de traduction, que je suis américain et mon français n'est pas très bonne.
g6dlrvzpjeebldqs.mediumd2suhqut3ynfs5sm.medium
Mar 07, 2011 | Nintendo DSi XL Burgundy
Bonjour comment l'activer pour pouvoir enregistrer le disc dur de mon portable merci
Bonjour Arnaud,
ce produit est habituellement livr? avec le LaCie Setup Assistant. Une fois celui-ci ex?cut?, votre disque sera disponible sur votre ordinateur.
Le produit est aussi livr? avec le Genie/LaCie Backup Assistant. Une fois install? et ex?cut?, ce programme vous guidera afin que vous configuriez la sauvegarde de vos donn?es vers le disque LaCie.
Si vous croyez avoir effac? par accident le contenu du disque avant d'installer le logiciel, il peut ?tre t?l?charger ?: http://www.lacie.com/download/drivers/LaCie%20Genie%20Backup%20Assistant%208.0.364.534%20Win.zip pour le PC et http://www.lacie.com/download/drivers/LaCie%20Intego%20Backup%20Assistant%201.0.1%20Mac.zip pour le MAC.
Vous pouvez aussi faire une copie directe de vos fichiers vers le disque LaCie comme s'il s'agissait d'un disque local.
Faites moi savoir si vous avez besoin de plus de d?tails.
Jan 29, 2011 | LaCie Rikiki Go 1TB USB 2.0 Portable -...
Bonjour , nous avons un Asko D-3120 j'entend le moteur fonctionner mais rien ne se passe a l'interieur et la lumiere de la tasse avec une assiette clignote sans arrêt . J'ai essayé...
le drain est boucher et la panne de reserve est pleine d'eau solution sort le lave vaisselle de sont emplacement et enleve le panneau arriere ensuite éponge l'eau et débranche le tyau de drain place le tuyau de rain dans un sceau et demarre un cylce de rincage et verifier si il ne coule pas lors du cycle dans la panne
Nov 01, 2010 | Asko Dishwashers
Bonjour ou se trouve le reste sur ce modele?? j'ai DEG de programme dessus et je ne suis pas capable de l'enlever. merci
écoute, ne te fâche pas : je ne comprends pas le sens de ta question et je devrais m'abstenir de te venir en aide, craignant d'interpréter incorrectement ton problème (et ce n'est pas ma maîtrise de la langue de Molière qui est en faute!!) Mais je vais quand même essayer de t'aider.
L'indicateur DEG que tu sembles vouloir éradiquer est parfaitement inoffensif. It est affiché sur l'écran pour te rappeler que l'unité d'angle est le degré. Cela signifie que tout argument que tu fournis à une fonction trigonométrique (sinus, cosinus, tangente, cotangente) est interprété comme une valeur en degrés. Donc si tu calcules sin(Pi) ne t'attends pas à obtenir 0 mais le sinus de 3,14.. degrés.
De même, toute valeur retournée par une fonction trigonométrique inverse ( arc sinus, arc cosinus, arc tangente, arc cotangente) sera en degrés.
Si tu changes l'unité d'angle de degré à radian, l'indicateur RAD sera affiché quelque part sur l'écran. Donc je te suggère de ne pas t'acharner à faire disparaître cet indicateur: Il ne fait que te monter quell unité d'angle tes calculs utilisent. C'est plutôt commode, ne trouves-tu pas?
Maintenant, si tu veux préciser ce qu'est ce reste que tu cherches, peut-être pourrais-je t'aider? Tu n'as qu'à faire un commentaire et je verrai ce que je peux faire.
Jan 17, 2010 | Casio FX-250HC Calculator
Computers & Internet Logo
29 people viewed this question
Ekse
Muntejaya Ginting
Muntejaya Ginting
