Question about Sharp Televison & Video
I just bougt a big 65" Sharp Aquos androud 4k TV. There seems to be somekind of auto brightness thing going on and it drives me mad. Is there a way to fix it in the new systems?
Posted by Anton Artby on
  • Sharp Master
  • 6,099 Answers
The auto-dimming is from the OPC (light sensor) control on the Sharp LC-65UE630X. Enter the menu and go to the TV setup portion of the menu system. Select the Picture sub-menu and set OPC to Off. This is shown on page 3-3 (page 24 of the PDF). Sharp has the manuals for their Android TVs here: https://global.sharp/aquos/en/androidtv/support/ . The direct link to the manual for the LC-65UE630X is currently https://global.sharp/aquos/en/androidtv/support/download/UE630X_65_58_50/UE630X_Series_user_manual.pdf .
I hope this helps. If you have a different model, please add a comment with the full model number. I believe the light sensor dimming will be in the same place across most Sharp models. I would only be able to confirm this with the model of your set.
Posted on May 22, 2020
5 Related Answers
Anonymous
SOURCE: My Sharp Aquos
Why does my sharp Aquos TV go out of resolution everytime I turn off the Wii game that is hooked up to it? Then I can reload Optimum cablevision- all I get is the program guide. Help
Posted on Nov 21, 2008
Anonymous
  • 31 Answers
SOURCE: Sharp Aquos LC-46d65U HDMI connect
First off a little tip that manufacturers don't tell you is that you HAVE to TURN OFF the POWER to ANY UNITS that you are Connecting to via HDMI!!!!!!! If not you can short out the Inputs!!!!!!!! HDMI is usually Automatic, But sometimes you need to go into the Menus on all Devices to the HDMI section and write down their settings and compare them. Any definition that you are not sure of check the Manual or Google it! Match all the Settings (there won't be Much!) Hopefully the Inputs were not Damaged it only takes one time to short it out and then the Repairman makes a few bucks! Good Luck!
Posted on Apr 29, 2009
ginko
Ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
Anonymous
SOURCE: Aquos Screen Image Too Big.
I had the same problem, but it looked like my son pressed the view mode button on the remote. I set it back to Dot by Dot and it looks perfect again. Try it out.
Posted on Sep 09, 2009
Chi Chu
  • 8457 Answers
SOURCE: We have a Sharp Aquos LCD TV 42 inch. When I
Call Sharp for warrenty repair.This problem very common in Sharp tv.Picture will come on turn power on/off button few times will work.But still under Wareenty call to Sharp to replaced the main Tuner Signal board.
Posted on Jan 15, 2010
Testimonial: "Have tried turning on/off a few times but still doesn't work. thanks anyway"
How to connect a Hk3800 to my smart tv 65 sharp aquos 4k
Try plugging the USB dongle for the keyboard into the USB port on the TV
Mar 24, 2018 | Sharp Televison & Video
My Sharp 55" Smart TV doesnt respond with remote
Try a different remote such as one for your bluray player to isolate if tv or remote
Nov 02, 2017 | Sharp Televison & Video
Can not get sound when connecting a samsung HW f355 soundbar to a sharp aquos 4k tv
There should not be any problem in connecting this TV to Sound Bar. Check all the connections. Contact any service technician to seek help in this matter. Refer the user manuals to both the sets.
Dec 02, 2014 | Samsung Televison & Video
Where can I get an HDMI board for my Sharp Aquos 65 Model LC65D64u
go to ebay and put your model tv in the searchbar followed by the word parts u may need a mainboard
Jan 29, 2013 | Sharp Aquos LC65E77UM 65 in. LCD HDTV
Sharp AQUOS 65" LCD, No Picture Menu Access
change picture mode from (STANDARD)or other modes and put tv in CUSTOM then you will be able to change the contrast
make sure all cables are in
Dec 15, 2009 | Sharp Aquos LC65E77UM 65 in. LCD HDTV
I am thinking about buying a used 65 sharp
I wouldn't recommend buying it unless it came with some type of warranty.
The most common thing you would be looking at for repairs if something goes wrong would be the Backlight Inverter Board or the Power Supply Board. It's what powers the big screen like that. Replacement board for one of them would be well over $200. And we're not talking about labor on top of that from the repair shop.
If you get it, try to get warranty with it. Add on extended warranty if possible.
Jun 04, 2009 | Sharp AQUOS LC-65SE94U 65 in. LCD HDTV
Picture fades in and out
Some newer TV's are equipped with a ROOM SENSOR which will change the Contrast and Brightness according to the amount of light going into the Sensor. While watching DVD's or Movies the output of light from the TV screen changes sometimes affecting the Sensor. While Computers are pretty consistent with light output.  Go into your TV Menu and look for ROOM SENSOR or something similar and turn it off. If not then check in the TV Menu Video controls and see if there are any Contrast or Brightness functions set to AUTO. If so grab a DVD with THX and they have a TV Calibration that is very easy to set-up your TV too.
Apr 21, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
LC-65D64U Sharp Aquos
Call sharp back again and tell them you first want to register for aquos advantage program, which is free. By doing that your service will go much quicker with them. You then tell them that you want to get set up for service. They will have one of their authorized professionals come and fix your tv in a matter of days. If their tech cannot fix it, they will replace your tv free of charge as long as you are within your warranty.
Oct 07, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-C32344 Manual
SHARP 65 LC65D90U 1080P HD LCD TV
I like this a product very much
muchhttp://www.eboyvip.com/goods.php?id=646
Jun 25, 2008 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Televison & Video Logo
Top Sharp Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
