Question about HP Computers & Internet
How to remove and replace motherboard on hp 310-1020 all in one pic.
Posted by Maynard Rossen on
Attique-ur-Rehman
    Top Expert:
  • HP Master
  • 2,673 Answers
Https://www.youtube.com/watch?v=1_ssncypf_I
Posted on May 22, 2020
  • Maynard Rossen
    Maynard Rossen May 24, 2020
    Your answere wasn't able to load. Was black lettering and not blue. Please resend the link you provided. And thanks for your time.
Where is the cmos battery located in a gateway p-7805U fx series laptop
It's a big job to get to it. It's located under the motherboard covered with black tape. To get to it you have to disassemble the entire machine and remove the motherboard to replace it. Here is a pic to show you.
May 10, 2015 | Gateway Computers & Internet
I want to add the hp 1270i to my hp computer how do i?
In order to replace the optical drive on your PC, you would need to first remove the side panel (opposite side that the motherboard outputs are on). Next, you disconnect the cables for your existing drive and motherboard (unless the drives are the same type of connection) install the replacement optical drive, connect the cables the the drive and your motherboard. Replace the side panel and you are done.
Oct 09, 2010 | HP Computers & Internet
My hp pavilion dv6500 won't boot up. When the power button is depressed, the power light, dvd light, and all other lights near the keyboard come on for a split second, then shut back off The screen never...
Start taking your laptop apart piece by piece and test it after each removed component:
1. Remove the hard drive and test the laptop.
2. Remove the DVD drive and test the laptop.
3. Remove the wireless card and test the laptop.
4. Unplug the display panel from the motherboard/video card and test the laptop.
etc....
Continue taking it apart until you have only three major components connected: motherboard (with video card), processor, and memory. If you still experience the same problem, most likely it's bad motherboard.
By the way, before you start, try reconnecting the memory module. If you have two modules installed, try removing them one by one and test the laptop with each one separately
Sep 19, 2010 | Microsoft HP Pavilion DV6276US Notebook PC
My HP pavillion laptop just shut down. I've been told a need to buy a new motherboard. ¿Where can I buy one at a reasonable price?
You might find a "used" one via eBay, but will it work?
Instead, access http://support.hp.com and get a genuine HP replacement part, and then find an HP-authorized technician to disassemble your laptop, remove the motherboard, install the replacement, and "test" the computer.
Jan 13, 2010 | HP Computers & Internet
Help to ID motherboard from Compaq 5000 series
there is a compaq part number printed on all HP/compaq components. if you search for that in google. you can find replacement parts
Dec 09, 2009 | Compaq Presario 5000 PC Desktop
How do i separate the top part from the bottom part of my laptop. I want to buy another motherboard, but I'm not sure I can do this stuff myself
I don't think you can, maybe you can separate it but how you sure that when you buy a new motherboard is working. Or maybe you can buy the exact design of motherboard is how you back back in. Even user manuals are not put to know how to disassemble the laptop. Only Certified Technician can do that my friend.
Just bring to your nearest HP Computer Center to let them provide all of it, at least you have warranty whatever problems occur again.
Hope this tip might help you.
Sep 23, 2009 | HP Pavilion dv1000 Notebook
HOW TO REPLACE HP DV4000 MOTHERBOARD
Check out the manual, located here:
http://h10032.www1.hp.com/ctg/Manual/c00530488.pdf
Check under the Removal and Replacement Procedures section.
Replacement for the Full Feature Motherboard can be found here:
http://www.getpartsonline.com/396696-001.html?source=googlebase&code=396696-001
Nov 25, 2008 | HP Pavilion dv4000 Notebook
Replace Damaged AC Power Jack
I have replaced alot of jacks in similar models as this one.
I don't have one in front of me, but, assuming you have removed the power button/hinge cover plastics, removed the lcd, removed the keyboard and then removed the palmrest plastics.... you now have a base with the motherboard still in it. There are a few screws that attatch the motherboard to the bottom black chassis. Just have to carefully look around the board for them and remove them. Also, might need to remove the lugs on the back where the video connector and paralell port is located. And disconnect a couple wires here and there.
If you had pics available, I might could be of more help. Trying to get a mental picture of what your talking about. I have taken apart alot of these, and can usually get one down to a bare mainboard within 5 minutes easily.
Are you still needing help with it?
Oct 20, 2007 | HP Pavilion ze4315us Notebook
Computers & Internet Logo
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
