Question about Power Computers & Internet
Pls my display panel does not show any light apart from the power
Posted by Samuel Peter udo on
bulbist
    Habit-Forming:
    New Friend:
  • 81 Answers
What display is it ?
Posted on May 22, 2020
1 Related Answer
Anonymous
  • 300 Answers
SOURCE: No display and no light indicators when powered on
If the printer control panel is blank when you turn on the printer, check the following items.
1. Make sure that the printer is plugged into an active electrical outlet that delivers the correct
voltage.
2. Make sure that the on/off switch is in the on position.
3. Make sure that the fan runs briefly, which indicates that the power supply is operational.
4. Make sure that the control panel display wire-harness is connected.
The control-panel wire-harness connector can easily be disconnected when you install the top
cover. If the control panel does not work after the top cover is installed, verify that the wire-harness
connector is fully seated into its DC controller PCA connector.
5. Make sure that the firmware DIMM and the formatter are seated and operating properly.
6. Remove any HP Jetdirect or other EIO cards, and then try to turn the printer on again.
If the printer control-panel display is blank, but the main cooling fan runs briefly after the printer
power is turned on, try printing an engine test page to determine whether the problem is with the
control-panel display, formatter, or other printer components.
Engine test page
To verify that the printer engine (all printer components except the formatter, formatter DIMMs,
EIO products, and the stacker or stapler/stacker) is functioning, print an engine test page. Use a
small, non-metallic, pointed object to depress the test-page switch, which is located on the right
side of the printer
The test page should have a series of vertical lines. The test page will print from the last tray you
printed from. However, if the printer has been turned off and then back on since the most recent
print job, the page will print from tray 2. The printer will continuously print test pages as long as
the test-page switch is depressed. The printer will not print a test page if it is in PowerSave
mode.
A damaged formatter might interfere with the engine test. If the engine test page does not print,
try removing the formatter and performing the engine test again. If the engine test is then
successful, the problem is almost certainly with the control panel, or the cable that
connects it.
Hope this helps
Posted on May 24, 2008
Why is the control panel (display panel) blank on my HP LaserJet M3035xs mfp?
The display panel connection is probably loose. The wires could also be broken where they flex whenever the top cover is opened. These are difficult to take apart but you can usually find how-to videos on youtube.
Feb 16, 2017 | HP LaserJet M3035xs MFP All-In-One Printer
Bare ile bo100 microwave won't go keypads seem to be ceased lights ok on display pls help
You can try unplugging the oven for at least 15 minutes to see if the control panel will reset on its own.
If that doesn't fix it, you might have a bad control panel, or oven may not be properly grounded.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Oct 02, 2016 | Microwave Ovens
Pls how can i unblock a pump on bosch logixx
Turn it anticlockwise
if it won't turn it has something inside jamming it
you will need to remove the pump and filter assembly and take it apart to clear it
Jan 08, 2015 | Bosch Logixx WFT 2806 Front Load...
Christie ds+6k, buttons getting power, LED display has no power, and will not powering on
Button Panel lights up with power cable in ,means the power supply is ok
pls check the mainboard
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Jan 11, 2014 | Christie DS 6K OEM Projector Lamp
I have a ford explorer 1995 The cruse control is out The 4x4 won't switch no light The dash display dosnt show or switch to c to f The compass dosnt work beside that the truck is perfect pls help pls...
4x4 common problems 1- 4-wheel drive module located at left real quarter panel 2- transfer case motor located on the transfer case housing Or you have some corroded wiring
Oct 21, 2013 | Cars & Trucks
Tv Wont Display
take your tv apart and find the compactor that blown up and change it
Jun 25, 2013 | Televison & Video
My printer canon 4412 not work the display showing on main switch e202-0002
hi my printer canon mf 4412 printer is not working it is showing error batten red light showing , display is not showing pls solve problem pls it is urgent
Apr 05, 2011 | Office Equipment & Supplies
Panasonic Plasma picture losing 50% of the screen!
it is likely the power supply board in the back of the tv. these are a huge problem. I fixed mine for $15 by taking it apart and taking the board to a repair shop. new cap on the board fixed it.
Mar 08, 2010 | Panasonic TH-42PWD5UY 42 in. Television
Unlock Deno 2910
Initially, pls try:
  • Verify that the tray is empty/no disc in the player;
  • Shut down/off with the front panel On/Off button and not the standby;
  • Press and hold the Open/Close, Play and Skip Reverse (I<<) buttons;
  • Maintain pressing on the above buttons and Power-ON the player with the On/Off button, (again while still holding the above buttons till the "Denon 2910" disappears from the display);
  • pls wait till LOADING completes and the front panel would display 0:00:00;
  • Using the remote control, enter 7, 3, 1, 9, 4, 6, 2, & 8;
  • The Denon 2910 will go into standby mode. Soon as it is on standby, pls press the Standby button on the front panel;
  • Pls verify region free update by pressing the Stop and Skip Forward (>>I) buttons on the front panel. The display would show “Region_Ax” The x would be the former region number that the Denon 2910 is locked into;
  • Should it not work ouot as expected, pls redo all the above steps.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 10, 2008 | Denon DVD-2910 DVD Player
No power at all!! pls help!!
Change C922, it's probably inflated and leaky
Nov 03, 2007 | Televison & Video
Open Questions:
Computers & Internet Logo
14 people viewed this question
Top Power Computers & Internet Experts
Gep Pep
EKASYS IT SERVICES
EKASYS IT SERVICES
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
