SOURCE: whirlpool refrigerator with freezer on
The drain line that comes through the casing may be plugged or the trap at the bottom of the hose where it drains into the drain pan under the refrigerator may be plugged. If water is freezing it is because it is being held back by a restriction.
SOURCE: How can you tell if your coolant has leaked out of your refrigerator?
Freon is a clear gas while at room tempertaure.
You would not see it.
Freon leakage is normally one of the last things to go wrong with a fridge.
You may want a second opinion.
SOURCE: freon leak in refrigerator?
no refrigerant leaks have little to no odor and if it was leaking bad enough to smell it the unit would be out of refrigerant and not cooling...the problem sounds like gases coming off of a veggie of something un-covered inside the fridge--have you put any veggies in the fridge or freezer un-covered check real good if one or a piece of something has fallen behind something else where you cannot see...all else fails remove all your products from the unit and clean and get a box of odor control arm&hammer to rid the smell..as for a leak in the sealed system i think your just fine.
