Question about Hitachi Televison & Video
Hitachi rear proj tv Channel Manager says " This Function is not available". How do I do a channel rescan?
Posted by doodlebug56 on
  • Hitachi Master
  • 6,099 Answers
First make sure that the current Source or Input is set to TV. This is usually the only reason for the error message you see. To select the source, look for a Source or Input button on the original remote. If you have an universal remote with a button with the Source/Input label, you may need to try alternative codes to make the button work. (Power and channel controls will often match across multiple codes for the TV manufacturer.) Alternatively, check if there is a Source/Input button on the TV or a section of the menu system with the function. Once you set this source, try again.
Note: there was a period when manufacturers sold some TVs without tuners. They were labeled HD-ready sets. These can't do a channel scan and do not have an RF antenna jack on the set.
I hope this helps. Please add a comment with the model number of your Hitachi TV for more information on setting the source on your set.
Posted on May 22, 2020
5 Related Answers
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Local channel went digital, lost signal.
You need a digital to analog convertor box to recieve the digital signal.
All UHF+VHF signals will be digital starting in June.
Thanks for using FixYa - a FixYa rating is appreciated.
Posted on Feb 20, 2009
Steve Yocum
  • 668 Answers
SOURCE: cant attain digital channel scan on hitachi rear projection tv
Do you have the tuner locked out for use of HDMI input only?
Most of the time when a selection is not able to be hi-lited it is
because a feature that is activated locks out other selections.
Hope this helps,
Skyassoc
Posted on Jun 17, 2009
mc88jj
SOURCE: My Hitachi HD 1080 will not let me access the
i am also having the same problem.how do you do a manual rescan
Posted on Jun 16, 2011
SD Tech
SD Tech
  • 14553 Answers
SOURCE: Vizio tv dropped a channel, won't rescan
Try with the remote to direct enter the channel number (with the number buttons and or enter) If set makes it there go into menu for option to manually add it to the set memory.
Not likely a problem with your set.
Posted on Dec 17, 2012
hichbiri
Huseyin Huseyin
  • 3469 Answers
SOURCE: When i click on The channel manager it says this function is not available. I have "no sync" and can't auto scan for channels as that option is in the channel manager.
Some setting or other appears to bave become mixed up. As with tvs malfunctioning with hardware faults please reset to factory
default and setup from scratch. This may remedy the issue.
Then , if the fault persists, try searching for the latest firmware for your set, this might do the trick
Posted on Jun 18, 2015
These answers do not fit my question. One day, on three different sets in my home, where I have received NBC for years just quit working. Did NBC quit broadcasting? It is not snowy, etc, it is just no
Ok This is what I found out and hopefully found your solution..
Have you heard of Double Rescan?
The Federal Communication Comission Designed a Process called double rescan.
Double Rescanning erases and thenreprograms the channels in the converter box an digital TVs memory.
To Double Rescan, you will first need to disconnect the antenna from the converter box or antenna.
Then disconnect the converter and or digital tv power supplies from the wall. Wait a minute before plugging them back in. The antenna should still be disconnected.
With the antenna disconnected run the channel scan function on the coverter box or digital tv. When the scan completes you will have completely removed any channel data the converter box or digital tv, had in its memory.
Now it's time to rescan for real.
Do this by reconnecting the antenna to the converter box or digital tv and running the channel scan function again.
Thus the double rescan is born.
If the double rescan doesn't work, then try some tips and tricks to get your converter box up and running..I will have to look up the url again that has the tips and tricks...
If the double rescan doesn't work let me know and I will look up more options..
I really hope this works..
Dec 18, 2014 | Samsung Televison & Video
One station only has lost sound but piture is great. All other channels work fine.
Have you tried retuning the TV? You may need to do a Full Factory Reset tuning rather than just a rescan.
Rescan simply looks at the place holders where the old channels were stored and refreshes them. A Factory Reset (A.K.A. Shipping Condition) wipes the channel memories and starts again fresh.
Sep 09, 2014 | Hitachi Televison & Video
Tv keeps asking for installation when switching on hitachi L19DG07UJ
Tune the TV in properly. Do a Full Factory Reset tuning rather than just a rescan.
Sep 03, 2014 | Hitachi Televison & Video
Why is channel manager option grayed out?
Channel manager may not be an available option for over-the-air viewing
Jan 27, 2014 | Hitachi 42 in. Plasma TV
I just set it up (it is used) and I can't get to the "Channel Manager" in the setup menu, as it is grayed out. I can't auto program because of my inability to access this menu function.
Channel menu will be grayed out if tv is set on AV Input, select TV source by remote or press any channel number to set tv on tv source, this will enable channel manager/ menu to tune channels in tv.
Hope these info will help you.
Thanks
Nov 25, 2010 | Hitachi 51F59 51" HDTV Projection...
I have a sony kp-57wv600 57 inch tv. and the channel button does not work. The channel button on the tv and the remote does not work. When I hit the channel button all that happens is the tv flickers but...
The first thing to do is to rescan for channels. If for some reason the channel memory got wiped out, there could be no other "available" channels to change to. The "flicker" you see is the TV changing to the same channel. Try the rescan and update this if that does not resolve the problem. Let's eliminate the simple stuff first. If the rescan DOES resolve the problem, please update this with that information as well and we will try to find out what cleared out the channel memory.
Thanks,
Dan
Aug 08, 2009 | Sony KP-57WV600 57" Rear Projection...
Cant attain digital channel scan on hitachi rear projection tv
Hope this helps,
Skyassoc
Jun 17, 2009 | Hitachi 51F59 51" HDTV Projection...
Channel changer locks up
Make sure you have the tuner set for digital channels only. then redo the channel search.
May 06, 2017 | Hitachi 57F500 57" Rear Projection...
Televison & Video Logo
21 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
