Question about Samsung Televison & Video
Samsung year 2008 67" DLP HL67A510J1F Lamp goes on for 4 minutes and shuts off. Tried two new lamps but same result. HELP!!
Posted by E Fudd on
Andrew Taylor
    Top Expert:
  • Samsung Master
  • 32,360 Answers
Cooling fan issue, overheating.
Old technology, you need a new 82" Samsung flatscreen.
Posted on May 23, 2020
Testimonial: "I have replaced the lamp via ShopJimmy three times. Last one lasted 5 mo. the replacement and it's replacement to check if prior was working, I have a super clean TV, there is no dust. I have complete access to the back of the tv from a different access door behind it, the fan runs, I'm at the 'maybe the ballast' and am cutting my costs and going for a new 70" something...can't chase this solution any longer though the cabinet was built around the TV in 2008...Thank you to all, and to all a good night!!! and all the suggestions."
5 Related Answers
Anonymous
  • 106 Answers
SOURCE: I have a mitsubishi WD-52525
Chances are the lamp is not bad. Is the lamp door reseated properly? The is an interlock on that door that must be activated in order for the set to turn on. If the unit was woking before the lamp went out this may be the problem
Posted on Nov 26, 2008
Anonymous
  • 261 Answers
SOURCE: DLP TV lamp went out, new one doesn't work either,
Well you have a Samsung TV, in this case, it's most probable that you might have an issuw with your ballast. It might not have enough energu to keep up with your new lamp. You might ask yourself, How could this be if it worked with the old lamp? Well the old lamp didn't have all of it's gases, like it used, when you recently purchased the tv or lamp, and as time goes by, those gases tend to go out.
Posted on Aug 11, 2009
MICHAEL MULLINS
  • 927 Answers
SOURCE: samsung dlp acts as though the lamp is gone. Put
It may be the ballast or aother problem. First, unplug your TV for about 5 minutes, plug back in. LISTEN very carfully when you turn the TV on. (put ear on the left hand side of TV towards the back) if you hear a clicking sound. It may be your light engine. BUT most important what lights on front panel are blinking.
Hope this was helpful, Big Irish.
Posted on Nov 21, 2009
Anonymous
  • 32 Answers
SOURCE: Samsung DLP
Yup definitely sounds like the ballast, if not then you have a problem in the power supply. Probably some bad capacitors. Call a local tv repair shop.
Posted on Jan 20, 2010
Kenneth Lee Sr.
  • 597 Answers
SOURCE: lamp went bad after 4 years. Replaced lamp, new on...
power board malfunction
Posted on May 22, 2010
When I turn the tv on it stays on for a few seconds then goes off,and around the power button it says lamp
Is this a DLP TV? if so you just need a new lamp $75-$200
This is easy to switch the lamp in DLP tv's they are made to be switched by the owner,
A lamp will last from 1-4 years,,
Jul 26, 2011 | Samsung Televison & Video
My Samsung 46in DLP turns on but within a few minutes it truns off and the timer, lamp and red stand by/ temp lights blink. Any Ideas?
The blinking lights usually indicate that the lamp is faulty or burnt out. In this case a new lamp would be required. The lamp in your projector set should last around 3-4 years of typical use. If your lamp is at the end of it's life you may have noticed a gradual reduction in brightness over the last few months. In this case if it's still in warranty contact Samsung to arrange for a replacement lamp.
Occasionally the lamp may not come on even when it is not burnt out. You could try turning the power off for 60 seconds on the back of the set. The other possibility is that the lamp is loose. Refer to your manual on replacing the lamp and follow the instructions removing the lamp and then put it back into place. If neither of these work you will need to get a new lamp.
Feb 28, 2011 | Samsung SP46L6HXX/XEU 46" HDTV-Ready DLP...
I have a Samsung HL-R5678W DLP TV that is acting up. When I first turn it on everything works, after 5 minutes it shuts itself off. After 2 minutes it will come back on without sound. It will do this a...
U turn tv on hear any squiling,grinding or motor noises?Picture show up before it shut down picture have flashes of black&white within the picture?Yes,to all of these,this tv have a colors wheel and it dead,require the colors wheel replacing.No,none of these problems.The tv projection lamp,if in this tv like a 1 1/2 or 2 years,tv ben on an watches like 4 or 5 hours a day?The "LAMP" LED light indication lite up or flahes,the projection lamp life is over.Require a new projection lamp.
Oct 22, 2010 | Samsung DLP HL-P5663W 56" TV
I have had this Samsung DLP HL-P 4663W for about 3 years now.
    1. Ensure that the TV is off. It may be advisable to unplug the TV as well.
    2. 2 Using a Phillips screwdriver, remove the single screw affixing the lamp cover (the small, grill panel on the back of the set) to the chasis. There is also a grill that is held in place by tension. Just "pinch" the thumb clamp on the bottom of the grill and slide it out. This is the same procedure you would perform to change the lamp, except in this case you will not need to remove the lamp itself.
    3. 3 Inspect the spring-loaded blue safety switch to ensure it is making good contact when the panel is secured. The switch should deflect downward when the panel is replaced. If the contact with the panel is suspect, very gently bend the metal bracket on which the switch is mounted.
    4. 4 Replace the grill cover and the lamp door, and continue to enjoy your TV.
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
  • 5.Check some basics first. Make sure the sleep timer on your TV hasn't been turned on, telling your set to turn off at a certain time. If your DLP TV is acting erratically, Samsung recommends turning the set off and unplugging it for 30 minutes. After 30 minutes plug it back in and turn it back on. Unplugging the set resets it, and that may fix the problem.
  • 6 Check your power supply. Make sure your Samsung DLP is securely plugged into a working outlet. Plug the TV into a different outlet to see if the problem still exists. Make sure that a fuse hasn't blown in your house or a circuit breaker hasn't flipped.
  • 7 Replace the lamp. If your Samsung DLP is shutting off or won't turn on, a bad lamp is the most likely cause. To replace the lamp, remove the lamp cover from the back of the TV by removing the screws with a Phillips screwdriver and slide it out and away from the TV. Remove the screws on the lamp assembly and slide it out of the TV. Disconnect the old lamp and insert a new lamp into the assembly. Slide the assembly back into place and replace the screws. Do the same for the lamp cover.
  • 8 Check for signs of overheating. Samsung DLP TVs generate a sizable amount of heat. If the components inside the TV get to hot, the TV will shut itself off as a protective measure. Make sure your DLP is out 12 inches or so from the wall. Make sure that all of the vents on the set are clear of any obstructions. Allow the TV to cool down for 30 minutes before turning it back on.
  • 9 Contact Samsung. If none of the above tips help, it's time to contact Samsung, as the problem is likely something that should only be fixed by a qualified service technician. More serious problems may include a bad power supply or a bad ballast. Attempting to repair those yourself will void your warranty and may cause more serious damage to your set.
  • The safety switch exists so the user does not accidentally remove the lamp door while the TV is on. Doing so could, theoretically, result in burn or electrocution. This spring loaded switch causes the TV to shut down when the door is opened.
  • Since the TV's chasis is plastic, expansion and contraction can cause the switch to lose firm contact with the lamp door. The TV's behavior could then be such that after being on for a while (getting warm) the plastic expands and the switch loses enough contact to cause the TV to shut down. The frequency with which this phenomenon occurs is not only dependent on the internal temperature of the TV, but also the ambient temperature of the room as well as the relative tension on the switch itself. The user's perception is that the TV starts up fine, but then "randomly" turns itself off after being on for a while.
  • If you have recently moved your TV, it is very common for random shut-downs to occur. This is because the move has shifted the flimsy plastic chasis of the TV, thereby loosening the contact between the lamp door and the switch.
  • Make sure your TV is off and cool when performing this procedure.
  • Sep 17, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
    My Samsung HLR5667W DLP won't come on. Lamp lite blinking
    Feel better now?
    Tried a new lamp or is it now very old and damaged the main board?
    Sep 20, 2017 | Samsung HLR5667W 56" Rear Projection HDTV
    could be the lamp, and is about time for a new one
    http://fixyourdlp.com/blog/?cat=4
    Jan 15, 2008 | Samsung DLP HL-P5663W 56" TV
    61" samsung DLP
    The original lamp code number and color wheel part number must match...give me all the # ' s for research = Model # , lamp
    numbers,color wheel numbers,etc.
    Also, does it "melody" on and " melody" off ?? That is a function
    of DMD module = might be defective...............T,
    Dec 20, 2007 | Samsung HC-P4752W 47" Rear Projection...
    Televison & Video Logo
    Muntejaya Ginting
    Muntejaya Ginting
    Ekse
