Question about Canon Office Equipment & Supplies
I have a canon 3460 printer which has been displaying processing A4 and it won't print just display only that
Posted by Issa Haruna Muhammad on
Attique-ur-Rehman
    Top Expert:
  • Canon Master
  • 2,673 Answers
Https://www.ldproducts.com/blog/troubleshooting-printer-problems/?__cf_chl_jschl_tk__=57ff8472707587e397338ac680e8416b03b6e9ae-1590087636-0-AU2bJlIHeL-DELCDXzQoTFGtLclBfIc4tXGr6ih9l_M1Wxndy9qw-fCAd3wtjRKn2RxyKRuVtySF1EU9F_iGoqC3UJyG_TwkNLy5fCYerQ2uqF8M7I2NuUeuRla-dTAUReJi0ZZ2oJzE-haTYlEL02535On9m-kDTgOeko_ylm4HOENUWnUV3hKfaB7lbUcW9u3P9fNZ9fBVzw_J6glphw6tPJ5m9eGClUQkbV7BRuNQfqkbZ19kKhpvlVCCR9kxkriVDbKXcyFkra7PSAUdnv8vAuW_CpGIRwbswoXWRlK-uxUSA__rBo7ylONwkQsDF06LTHodOU3HCkg9OESvZryGYPbHXLcIfM9XOd9DQrEoM9N4dHaLVV-B6FhRhRFGUw
Posted on May 21, 2020
  • Issa Haruna Muhammad May 21, 2020
    Not relevant
  • Attique-ur-Rehman
    Attique-ur-Rehman May 22, 2020
    CANON
    PIXMA MP450
    Discharge of the code of the error of the overcrowding of sump - "pampersa"
    1. You will turn off printer.
    2. retaining button Resume/Cancel (red triangle in the circle) press button POWER - indicator it will catch fire by green color.
    3. you will let go button Resume/Cancel, continuing to retain POWER.
    4. press button Resume/Cancel of 2 times, retaining POWER, after which you will let go all buttons.
    5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!
    6. you will turn off printer by button POWER.
5 Related Answers
Anonymous
SOURCE: canon printer displays error
CANON
PIXMA MP450
Posted on Dec 06, 2007
Anonymous
  • 32 Answers
SOURCE: error 6A80
Error 6A80 indicates that "an error occurred in the APP motor
during purging operation". Either the sheet feed unit, purge unit, or logic board could be at fault.
I'd recommend bringing the unit into your local canon authorized service facility for complete diagnostic and repair.
Posted on May 28, 2009
Fixe_You
Jalal Sordo
  • 1800 Answers
SOURCE: printer x6570 won`t print photos and data, or scan...
try uninstall the driver and insatll it after that reboot and connect printer!
Posted on Jun 05, 2009
komguy
Craig Gillette
  • 2306 Answers
SOURCE: My printers color ink cartrige has run out. I
All the Canon machines are that way, you won't be able to print unless you replace the color cartridge as well. There is not a way even in service mode to bypass this condition, they want you to buy more ink.
Posted on Feb 01, 2010
Testimonial: "Thanks!"
marjov
SOURCE: Canon BJC-70 color bubble jet printer
I need printing head for black print. Where to find it?
Posted on Jan 25, 2011
Canon ir 2420 every thing are good but printer display : load correct paper A4 Plaint copy.
Dear
If you have done all the things, there might be problem with hardware. If the display shows after the paper taken from tray, then replace the paper size detection switch inside the tray.
Thanks.
Jan 20, 2015 | Canon Office Equipment & Supplies
How to change A4 display to LTR display
Go to Printers and Faxes, right click on the printer icon and select Printer Properties.
then select the paper type as LTR.
If in case you do not get the option, re-install the printer drivers.
Sep 08, 2014 | Canon iR5000-6000-L1 PS Ver 1.0
How to do a print test on canon mp460 printer after replacing cartridge?
Print the nozzle check pattern to determine whether the ink is being ejected properly from the FINE Cartridge Nozzles. Use this function when the printed results are blurred or the color is incorrect. sikaku.gif Performing Maintenance 1 Press [ON/OFF] to turn ON the machine.
2 Press [Menu].
3 Display the Maintenance screen.
(1) Use [l_mark_s17.jpg] or [r_mark_s18.jpg] to select <Maintenance/settings>, then press [OK].
The Maintenance/settings screen is displayed.
(2) Use [l_mark_s20.jpg] or [r_mark_s21.jpg] to select <Maintenance>, then press [OK].
The Maintenance screen is displayed.
(3) Use [t_mark_s23.jpg] or [d_mark_s24.jpg] to select the setting item, then press [OK].
The setting screen for the selected item is displayed.
sikaku.gif Printing The Nozzle Check Pattern 1 With the machine ON, load a sheet of A4- or Letter-sized plain paper in the Auto Sheet Feeder.
2 Print the Nozzle Check Pattern.
(1) Display the Maintenance screen.
(2) Use [t_mark_sas25.jpg] or [d_mark_s26.jpg] to select <Nozzle check>, then press [OK].
The pattern print confirmation screen is displayed.
(3) Use [t_mark_s28.jpg] or [d_mark_s29.jpg] to select <Yes>, then press [OK].
The nozzle check pattern is printed.
Mar 31, 2010 | Canon PIXMA MP460 All-In-One InkJet...
Auto head alignment
#1 of 2
Carryout a Manual Print Head Alignment If Possible.
If the results of Automatic Print Head Alignment are not satisfactory, follow the procedure below to perform Manual Print
Head Alignment.
1 Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Cassette.
Important. You cannot print the print head alignment pattern if paper of size other than A4 or Letter is loaded. Be sure to use A4 or Letter-sized plain paper.
2 Open the Paper Output Tray, and then open the Output Tray Extension.
(1) Put your finger in the rounded indent of the Paper Output Tray and open it gently.
(2) Open the Output Tray Extension.
3 Press the Paper Feed Switch to select the paper source where you have loaded paper.
4 Select Settings on the HOME screen.
5 Select Maintenance, then press the OK button.
6 Select Manual head align, then press the OK button.
The confirmation screen is displayed.
Note. If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
7 Select Yes, then press the OK button.
8 When the Print Head alignment pattern is printed, select Yes, then press the OK button.
9 Look at the printout. From the patterns, select the most even, least irregular patterns for each column and input their numbers. Press the OK button.
(1) Select a column to input the pattern number.
(2) Use the or button to input the number of the pattern.
(3) Repeat the steps (1) and (2) until you finish inputting all pattern numbers, press the OK button.
Oct 08, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Print page settings revert to 6x4 when using as a photocopier, rather than A4
1-In copy mode, display the Settings screen by pressing "Settings" on the MP500.
2-Select the Setting Tab using the left and right arrows.
3-Select the page size by using the up and down arrow.
4-Select "A4" by using the left and right arrows.
5-Complete the setting by pressing Settings
Aug 04, 2009 | Canon Pixma MP500 All-In-One InkJet...
COUNTER CHECK "CANON IMAGERUNNER 2200" BLACK AND WHITE
On the left side of the on/off switch is there a small button mark with 123 press that button and the meter reading will display.
101 TOTAL ***** -that will be the total of copies,printing,and fax receiving on A4
103 TOTAL LARGE ******-this is the total of the A3 copies,printing and fax receiving made
201 COPY(TOTAL) -this is the total A4 copies
203 COPY(TOTAL LARGE)-this is the total for A3 copies.
Apr 02, 2009 | Canon imageRUNNER 2200
Canon pixma mp780
From the front panel (Macintosh and Windows)Press MENU or SETUP (depending on the model).
Press the right ARROW repeatedly until the display window reads Maintenance.
Press ENTER.
Press the right ARROW repeatedly until the display window reads Align Print Cartridges.
Press ENTER. The unit will begin the alignment process and the display window will read Printing Alignment Page
Verify that the alignment was successful after the page is complete.
Jul 11, 2008 | Canon PIXMA MP780 All-In-One InkJet...
22 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
