Televison & Video Logo
Question about Vizio Televison & Video
Hi, I have Vizio d65u d2 Screen goes black after 3 minutes, I change power board supply and led board, but still same problem
Posted by jorge velasco on
Mr.Mike
  • 580 Answers
Hello
Make sure the connectors are snugly in place and that the set in not i a position that stress the boards, reset all settings then
change the picture mode to standard and auto brightness to medium
Good Luck
Mr.Mike
Posted on May 20, 2020
1helpful
2answers
D65u-d2 black screen diagnosis
I would have attempted a system software update first once the screen went black. I would also disconnect all accessories. Then, if still failing, I would schedule a repair with a tv repair shop because it's dangerous to deal with internal portions of the tv as a consumer.
Thank you.
2helpful
Vizio D65u-d2 Backlight not working after replacing 2 LED strips?
You should be able to replace just the bad LED strips however with as much work as it is to get the set apart and back together I always replace all them as other strips generally fail in time. Did they all light up after you replaced the bad ones before you put it back together? This model set has local dimming so servicing it is a bit more complex, you could have a bad backlight driver but that board seldom gives issues, also you could have main or power board issues as power for the backlight driver comes from the power board or you could have main issues as it's the signal from there that turns on each strip.
2answers
Model d65u-d2. Why does it have a black screen?
only an educated guess back light is the problem , might be power supply of the led strips call a local repair shop
Why is my D65U-D2 Vizio screen going black?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main digital board./
Open Questions:
Top Vizio Televison & Video Experts
Marvin
Marvin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
