Question about Furniture
I have a Cuisinart wine cellar model CWC-1600 and nothing on it is working now. I took the back panel off to see if I could identify anything that was obvious but don’t really see anything. When I plug the unit in the fan spins a quarter turn and stops. No lights come on inside of the unit. Does it sound like a power supply issue? If so how do I repair the power supply?
Posted by John Mrozek on
ray gallant
    Top Expert:
  • Furniture Master
  • 68,585 Answers
SOUNDS LIKE IT MIGHT BE NEEDING A FAN THAT RUNS
Posted on May 20, 2020
2 Related Answers
Anonymous
SOURCE: Cuisinart wine cellar CWC-900 "Both fans are dead"
CONTACT COMPANY : DENVER BETA 303-431-7161 MODEL # YW06010012SL ONE MONTH LEAD TIME... THIS IS A SLEEVE BEARING MODEL THEY HAVE A BALL BEARING MODEL THAT SHOULD WORK ITS GIVEN MODEL IS YW06010012BL REPLACES DFC601012L
Posted on Nov 03, 2009
ray gallant
  • 68585 Answers
SOURCE: cuisinart wine cellar CWC-1600. Under $20 PS repair?
sorry FIXYA does not have a repair shop
Posted on Dec 25, 2017
Cuisinart wine cellar CWC-1600. Under $20 PS repair?
Dec 25, 2017 | Furniture
Cuisinart cwc800 wine cellar stopped chilling, fan runs well but no chilling occurs
You can get one on Amazon for $159 - service call and parts alone would be more than that.
Amazon com Cuisinart CWC 800 8 Bottle Private Reserve Wine Cellar...
If you need further help, reach me via phone at https://www.6ya.com/expert/michael_e7c2c48c6e65f808
May 02, 2017 | Televison & Video
My power supply keep on blowing fuse. I tried replacing fuse twice and immediately blown when plugin power. What could be the reason?
A dead short is more than likely. Potentially a shorted out compressor or wire pinched or a bad control board. I'd check the compressor terminals to ground, any motors to ground. With and without the wires hooked up to them. If the compressor or fan motors are grounded out it could cause that symptom. If you test them with the wires hooked up it will tell you if the wiring is shorted to ground.
Mar 24, 2016 | Cuisinart Cwc-1600 16-bottle Wine Cellar...
Why doesn't it cool?
If I unplug the Peltier the unit starts right up, the display working again and fans come on . Is Peltier shot ?
I also can't find the 4.5inch fans for unit Fan Model # SD1225S12L. What would happen if I leave Peltier unplugged ??
Dec 17, 2015 | Cuisinart CWC-1600 Private Reserve Wine...
My cuisinart wbc-1200 turns on and works but does not cool. how can i fix it?
I have the same problem. Fans worked fine. I took it apart and found bad thermoelectric cooling disk. Bought replacement on Ebay for $6.
Feb 01, 2011 | Cuisinart CWC-1200 Wine Cooler
Sep 04, 2009 | Cuisinart Private Reserve CWC-900 Wine...
As I can improve the yield of refrigeration of the digging, it is already difficult to maintain the indicated temperature
Here is the breakdown on this machine by temperature - it only works optimally in a room that is 68-70 degrees, which is a little on the cold side:
to actually reach 7 degrees Celsius, the room temp must be 68 degrees Farenheit or below
to reach 9 C, room must be 70 F or below
to reach 11 C, room must be 72 F or below
ETC...
all problems with this wine cellar will be aggravated during the summer months
Jul 22, 2009 | Cuisinart Private Reserve CWC-900 Wine...
Furniture Logo
101 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Furniture Expert? Answer questions, earn points and help others
