Question about Toys
Peg Pegro Ranger RZR does not go reverse - Toys
Posted by frank on
Kardoc
    Top Expert:
  • Toys Master
  • 6,115 Answers
Sounds like the control switch has an open in it. Move it back and forth several times to see if it gets a connection back.
Posted on May 20, 2020
We got a 24 volt rzr for christmas. it will not go in reverse, what can i check?
hi, its probably the forward/reverse switch. if it got wet its possible it failed or was just bad from the start. it should still be under warranty...call peg perego USA Ride-On Vehicle Customer Service: (800) 728-2108 . they have great customer service usually, just let them know how disappointed you are with such an expensive vehicle. how long does the battery last? they are usually pretty sensitive to batteries not meeting expectations and might send you another one.
good luck!
Feb 03, 2011 | Polaris Ranger RZR Ride on Toy
How do I loosen the rear wheels to replace a broken one on the Peg Perego Ranger RZR. I can't get either nut to break free from the axle.
You will need 2 wrenches. Both 1/2". Put 1 on each end of the axel and remove the nut on either end. You can then slide the axel out. You may need someone to help.
Dec 01, 2010 | Polaris Ranger RZR Ride on Toy
How do you remove the rear wheels on a Peg Perego Polaris RZR? I cannot seem to loosen them
remove the center cap and then bend the wire push nut in half with a needle nose pliers
Sep 18, 2010 | Polaris Ranger RZR Ride on Toy
How do i replace the rear tires on a peg perego ranger rzr 700. Having trouble removing the tire
remove the center cap and then bend the metal push nut in half with a needle nose pliers then it shoudl pull off
Feb 28, 2010 | Polaris Ranger RZR Ride on Toy
Hi, I have the peg perego ranger RZR....I need to figure out how to take the wheel off...
Jun 23, 2009 | Polaris Ranger RZR Ride on Toy
I just put together a Peg perego Polaris RZR ride on toy and it will go forward, but not reverse. The light showing a full battery goes OFF when I try to put it in reverse. Any ideas? Is there a loose wire...
For this Peg Perego Razor model, some of them have a lever that slips over the foot pedal to keep it from going in reverse for safety reasons.
I would check the foot pedal and see if it has one.
Let me know what you find.
May 06, 2009 | Polaris Ranger RZR Ride on Toy
Can't find the battery
2 screws under the passenger side seat. The whole seat will come off.
Mar 15, 2009 | Polaris Ranger RZR Ride on Toy
Toys Logo
46 people viewed this question
Top Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
