Question about Mitsubishi Televison & Video
My 65 Mitsubishi DLP TV model # WD 60736 has a dark picture. I have changed the bulb twice and maxed the brightness and contrast controls and the picture is sill dark. How can I correct the problem?
Posted by Bill Richardson on
Mr.Mike
  • 580 Answers
Hello There!!!!!!
Well this is gonna take some work... First thing to start with is...
When you replace the bulb/s -does the bulb actually illuminate?
If you shine a very bright light into the surface of the screen can you see a faint image of whats on the set?
Do you get sound?
If the bulb is illuminating, is it blowing soon after?
Did the set return to normal operation after replacing the bulb the first time?
Side Note-Never touch a high power bulb glass enclosure because you can leave oils and moister that lesson the life of the bulb or make it more prone to blowing. I have no facts to support this note beside my own experiences but this is a known "thing".
Questions? Just ask. Mr.Mike
Posted on May 20, 2020
4 Related Answers
Anonymous
SOURCE: wd-62825 mitsubishi dlp tv
Had the same problem. Service replaced the lamp engine. It did help.
Posted on Jan 28, 2009
Derrick Buckles
  • 74 Answers
SOURCE: tv picture is too dark- worked with contrast and
This sounds like low screen voltage(A1)try adjusting the a1 voltage bottom control on flyback transformer if you have a voltmeter, voltage on crt base possible market screen or A1 shoud be beteen 350/500 volts when making adjustment remember to take into account current taken by meter If voaltage will not adjust flyback transformer will have to replaced
Posted on Mar 06, 2010
SD Tech
SD Tech
  • 14553 Answers
SOURCE: vivitek dlp projection TV is dark despite adjusting brightness and contrast.
I presume optical lens and mirror are both clean?
Posted on Apr 10, 2012
SD Tech
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi WD- 73737 73 in. Screen if dim or dark. Changed contrast, brightness, and restored default settings but that didn't work. Help?
I am not sure about your model but a call to Mitsubishi to ask if the set has one or two mirrors would offer a possible explanation---the ones with two mirrors have a small one at the bottom--it gets coated with dust and brightness drops up to 75 percent----other possible reason is the lamp may be nearing the end of its life.
I would have Mitsubishi look to see if this model uses the two mirrors--if that is the case cleaning will cure this--if you find it has two mirrors I can tell you what is involved--on Vacation but do look here--let me know what you find.
Posted on Jun 26, 2012
On my WD-60C9 60 DLP HDTV the picture is really dark, colors are still ok but the entire picture is dark
Have you tried changing the brightness and contrast with the picture controls? If that doesn't solve the problem, it's possible the lamp box and lenses in front of the bulb need cleaning.
Feb 20, 2017 | Televison & Video
Picture is dark. cleaned the lens and tried to adjust brightness
have you changed the bulb. over time it will go dark as the bulb burns out...
Oct 21, 2013 | Mitsubishi WD-73C9 73" DLP TV
Dark Picture
Get a lamp ordered asap. It won't be long and you are going to need it. You lamp is on it's last leg.
May 16, 2010 | Mitsubishi WD-65731 65" HDTV
Turned on tv, no picture, only sound
the problem is likely the projection lamp .. you can replace that yourself if you are handy .. you must unplug the set and make sure everything is cool ...avoid getting finger prints on the new lamp ...here are a few places where you can get a new lamp ... you can also see what it looks like on this site ...
http://www.bluestar-online.com/Mitsubishi_Model_WD_65731_Replacement_DLP_Lamp_p/wd-65731.htm?gclid=CLb9k4zf-6ACFdk55QodwT3dxw
the lamp is likely in a cubby in the back of the set (where you used to see the bright light) ...
the lamp is mounted in a cage ... you can get the lamp already mounted in a new cage from here ...
http://purelandsupply.com/WD65731-Mitsubishi-DLP-TV-Bulbs.html
......it costs more mounted but its easier to change and you will need a new cage if yours is damaged .. from the site above you can see what the cage looks like with the lamp already mounted ..
your lamp is a model 915p049010 ... that is available thru amazon at a good price here:.(includes cage)........
http://www.amazon.com/Mitsubishi-915P049010-Lamp-DLP-TV/dp/B001AJ8RAA/ref=dp_cp_ob_e_title_0
Apr 10, 2010 | Mitsubishi WD-65731 65" HDTV
Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Feb 14, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi 57" DLP. Replaced bulb, now picture is hazy.
Cleaning th mirror and lense will remove the haze. This oldel is much older that 2 years though.
Jan 24, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Wd-62825 mitsubishi dlp tv
Dec 18, 2008 | Mitsubishi WD-62825 62" Rear Projection...
Televison & Video Logo
55 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
