Cameras Logo
Melody Mosher Posted on May 19, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the driver, trying to use my GE camera with my laptop, it says after driver is installed I should be able to retrieve photos
Tony Parsons
Level 3:
  • GE Master 6,405 Answers
  • Posted on May 19, 2020
Tony Parsons
GE Master
Level 3:
Answers
6405
Questions
Helped
1652072
Points
20272
The driver is the software which enables the laptop to communicate with the camera. It will have been installed when you installed the software from the CD which came with the camera.
11helpful
5answers
How to recover deleted photos?
Simply put, chances of recovery can be high as long as you act as soon as possible and stop using the Samsung digital camera to take more photos or videos, also keep the camera memory card in good shape (no physical damage).
Then you can rely on a digital camera data recovery software to get the job done and retrieve your photos. Here shows a list of good ones (for PC/Mac) http://www.digital-camera-recovery.com/
You'll need to connect the camera (mass memory card) to your computer. Then install the program to start scan & recover your files. Should be easy to get back your lost memories!
Regards
I want Cyber-shot DSC-H10/B Digital Camera drivers for window 7
Your camera should be supported by default without adding any drivers. All you need is a program that will retrieve the photos for you from your camera.
I suggest that you download and install Picasa and use that to manage your photos and retrieve them from your camera:
https://www.google.com/picasa/
2answers
1. When camera is powered off, lens will not retract. "Whirring" noise heard 2. When camera is powered up the lens will extend. However there is no image seen on the screen when the camera...
Well If the photos you want to retrieve are on the 15Mo of internal memory, there is not much to do here except to see a repair center.
If they are not on the internal memory, open the Battery hatch of your camera, push on the small card that is close to the battery, then take the card out.
Now you can plug this card directly in a card reader.
If you have a laptop you might have a compatible card reader on it, otherwise buy one, it is always usefull.
Retrieving the photo this way on any camera saves battery and is usually faster than when using an USB cable.
Hope this helps
2answers
How do I transfer my photos from camera to computer - out of town with no manual
First of all computer need compatible camera driver/software to communicate with your device (camera), you can download camera driver from its manufacturer's (camera) website. After installing camera software/driver into your PC (Computer). Connect your camera with computer through USB Cable that came up with the camera and transfer photos.
Thanks...!!
2helpful
I put the xd picture card in my laptop and unable
Try to use the usb cord that came with the camera to transfer photos over. Don't forget to install the driver for your camera.
http://www.olympusamerica.com/cpg_section/cpg_support_product.asp?id=1351
http://www.olympusamerica.com/files/oima_cckb/FE-310_X-840_C-530_Instruction_Manual_EN.pdf
The 2nd link is the manual in .pdf form, and there should be a usb cable that came with your camera and if you lost the cd-rom then you can download drivers for free from the olympus support site (1st link).
Good luck on retrieving your pictures.
Windows needs to install driver software for your canon...?
try re installing the software again, or maybe its not compatible. try and update via internet
2answers
When i insert my sd card into the port on my laptop nothing happens. how do i retrieve my photos
try reinstalling the driver for the card reader or try it on another computer if nonthing happens then format the memory card
Error message when I try to download photos to my laptop
Did you install the drivers from the CD which came with your camera???. The drivers must be installed, before you can connect your camera to your laptop. If not follow these steps in sequence
1- Use the CD to install the drivers. If you do not have the CD, please go to fuji web site and download it. Here is the link
http://www.fujifilm.com/products/digital/download/01/index.html
2- After installing the drivers, connect your camera to your laptop, turn it on and follow the screen to install the drivers.
3- After it is finished (ready) , click on start, then computer. If the drivers was installed correctely, you would see an icon with all or part of fuji Finepix s9000. Double click on that icon.
4- You would see one or more folders, which contain all of the pictures and/or videos stored in your camera.
Now you could download, copy, delete etc all of your stored pictures.
GOOD LUCK!!!!!!!!!!
Retrieving photos on PC
I don't think so.
Are you opening the drive that says digital camera or are you opening the drive that shows a little icon above it - meaning it has content? If you are using the digital camera drive , open it up and see how it is configured. Is your camera chosen? Are the other options correct? Mine does not have the option for any of my cameras, and my photos download to my F drive. If your problem is not solved here, try this:
I would try going to pentax and looking for an updated driver for your camera and op system and doing a clean download(nothing running-not even virus control)and install.
First however, you will need to uninstall and go to tools>internet options>delete cookies
when you have finished a clean download and install, restart your computer and try to download photos. Also try a different USB socket.
Good luck to you.
Top GE Cameras Experts
ZJ Limited
ZJ Limited
Jerry Naidoo
Are you a GE Camera Expert? Answer questions, earn points and help others
