SOURCE: Hotpoint fan oven motor removal
hi it is left hand thread i just checked it with a brand new one i have here :- turn the spanner or socket to the right to take it off
SOURCE: how do I remove the fan from an electrolux EGC652 oven
The model no. does not seem correct.but it seems as if the hole in the fan blade which is normally D shaped has worn round.The thread on the shaft is Left handed and you will need to undo by turning clockwise. If you can get a vice grips at the back of the blade to hold the shaft then try again,or you will need to get into the back casing and try jamming the shaft at the motor housing you may need some help.Then if that works you will need to undo the 3 bolts holding the Motor body to the rear casing.The new fan would normally come with new bolts,blade and nut.To tighten fan blade nut use a 10mm socket hold the fan blade and tighten anticlockwise.Hope this is helpful.
Good luck.
Testimonial: "This answer is what I was planning to do and had assumed was the likely cause of the problem. Thanks to the respondent."
