SOURCE: 24 in. built-in, over 7 yrs old Bosch dishwasher
Sounds like a problem with the programmer, insert model number here to find the replacement.
SOURCE: 7 year old dishwasher motor needs replacement
No one is going to do anything for you at 7 yrs old- maybe 13 months, but not 7 yrs.
SOURCE: warning light focus st170
Pretty much. The temperature is low enough that if your engine is not properly prepared for the cold you could experience engine issues. i.e. Frozen radiator, tube failures and other issues like low viscosity oil which would create lubrication issues and premature pump failure. Best to ensure that your car is wheater ready for the cold. DRRXR :)
SOURCE: Blinking Clean light in Whirpool dishwasher
Control is programmed to stop
running and not allow any
further cycles if it detects a
water heating problem (no
temperature increase detected
in heated Main Wash on
3 consecutive cycles). Control
blinks the Clean LED 7 times
repeatedly and disables the
Start/Resume key until
cleared.
Running Diagnostics clears the
control and allows it to operate
again. The water heating problem
must be fixed or the control will
stop running again. See potential
causes below.
Heater circuit problem:
■ Open in heater.
■ Open connection or
component in heater circuit.
■ Faulty heater drive circuit on
control.
1. Check operation of heater in
Diagnostics cycle.
2. Unplug dishwasher or disconnect
power.
3. Check resistance of heater and all
components and connections in the
water heating circuit or heat dry
circuit.
dont forget to vote
hope this helps
thank you
SOURCE: 1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
