Question about Food Processors
The on/off switch on my HMP food processor seems to be stuck Is there a way to release it? to
Posted by George Davenport on
Myfp14dc food processor is stuck in ON. Once plugged in with the cup latched on, it will run continously, like if the pulse button was stuck in ON. Ideas?
Hi, yes the "on" button is stuck.... try giving it a smack or two to see if it will release, but be careful not to hit it too hard ok?
Mar 30, 2018 | Food Processors
Pastry blade won't release
This is the kind of thing it would be very difficult to fix without being there in person. Do you still have the manual? It's possible there's some well hidden button or latch you have to hold in while you remove it. I tried to find a manual online, but was unsuccessful. I did see where you can purchase one - though I doubt you'll want to pay the $16 for it. But, just in case, here's the link: http://cgi.ebay.com/Cuisinart-Pro-Classic-DLC-10S-Manual-Recipe-Book-NEW_W0QQitemZ190147128664QQihZ009QQcategoryZ20673QQcmdZViewItem
Sep 07, 2007 | Cuisinart DLC-10S Pro Classic Food...
How do I release lock mode on majic bullet?
Push down and twist.
https://www.nutribullet.com/customer-service.html
May 04, 2014 | As Seen On TV Magic Bullet Food Processor
Work bowl stuck.
Hello. It will release. Just use a wooden spoon wrapped in a towel to gently tap on the handle until it moves and releases. J.
Jul 05, 2010 | Cuisinart DLC-2009CHB 9 Cups Food...
I cannot remove the top from the base
I don't know what brand food processor this is. However, are you saying that the bowl will not rotate to release? It's normally just a matter of twisting the bowl (probably anti clockwise when viewed from the top) in order to release it.
Apr 12, 2010 | Cuisinart DLC-5 Food Processor
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
http://www.cuisinart.com/share/pdf/manuals/bfp-10ch.pdf
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | Cuisinart Food Processors
The plastic ? bowl of the processor is stuck
With the food processor I have it will not allow you to remove the bowl unless the top is off.Try take the top off or putting it on.Then remove it from the processor.
Sep 22, 2008 | KitchenAid KFP670 Ultra Power Food...
Stuck sunbeam blade on spindle
Put some water in it and run it for a minute or so. That helped me with the same problem on the same processor.
Aug 12, 2007 | Sunbeam 4816-9 Food Processor
Food Processors Logo
48 people viewed this question
Top Food Processors Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Food Processor Expert? Answer questions, earn points and help others
