Question about Pool & Spa
Looking for deluxe portable spa 23055 cover top and bottom I have a Deluxe potable spa model 23055 we're can I get the protective cover top and bottom
Posted by Michel Lev on
5 Related Answers
Anonymous
  • 99 Answers
SOURCE: RIBBON CHANGE
Make sure the ribbon is facing the correct side. Usually, there is a small encave which is to be facing downwards. Snap it in place and you are good to go.
Zabrina
Posted on Feb 07, 2008
Anonymous
SOURCE: Unlock codes for Video Explosion Deluxe
To work with MPEG-2 files, you must do a separate, one-time online registration. Video Explosion will automatically prompt you to register the first time you add or create an MPEG-2 file in Video Explosion. They will send you the unlock keys. Since the company no longer supports it, I guess nothing can be done. I got my keys awhile back and enjoyed doing videos for events. I am running Vista now which cannot take Video Explosion Deluxe so I'm screwed as well.
Posted on Aug 09, 2008
greenspan
Remmy Moore
  • 1734 Answers
SOURCE: I need a Sunbeam/Oster Deluxe Bread & Dough Maker Manual Model 5811
Hi, for any Sunbeam or Oster manuals ask http://manualfox.com - they can get you nearly every manual.
Posted on Dec 15, 2008
bansheracer
  • 1089 Answers
SOURCE: Grinder settings for Vienna Deluxe
Hi
To start off with, you should not change the big knob unless the grinder is operating at the time.
Set the small knob to the middle position. You can move this any time. Move towards the + mark to strengthen the coffee, but never all the way to the full +.
Set the big knob to the #8 to start off with. Move it 1 # smaller to make the coffee stronger but be careful not to get it to fine as you will clog the grinder and you will have to take it apart to clean. If you ever get an out of beans light, but there are beans in the hopper, open the knob to #16 for 1 cycle, then turn it back down to a # 1 larger than you had before and leave it unless you get the message again. Shiny beans call for a coarser grind than a dull bean because of the oils in the coffee bean. Oils will cause the grinds to stick together and cause clogs faster than beans that have less oil.
Posted on Jul 16, 2009
Anonymous
SOURCE: top tray not draining
I called the service tech, before Maytag stopped supporting this unit. (built by Fedders with Maytag name). Fedders has gone out of business (7-09). The tech guy said that the tray gets clogged up with crud and the solution is to try to flush the tray out with water and compressed air. I had the problem of water leaking from the trays but not properly draining through the drain hose. This solution did the trick.
Posted on Jul 25, 2009
Harley torque specs
Install primary cover and gasket using the sixteen screws with captive washers tightening in sequence from center to front alternately top then bottom the middle to rear alternatively top to bottom to the rear of the cover to 100-120in-lbs (11.3-13.5 Nm) in sequence.
May 02, 2014 | 2006 Harley Davidson FLHRCI Road King...
Sofina portable spa
there is a pressure switch and it may be the problem, its usually next to the heater with 2 wires, it might just need a light tap with a screwdriver handle (LIGHT)... the spa must be full of water
Sep 26, 2013 | Pool & Spa
Dress Maker Model KNS Deluxe Zig Zag
If you are looking for a manual go here:
http://www.sewusa.com/
manuals - deluxe zigzag - kns
This machine was imported by several companies so a generic booklet was made. I have the same machine and the one the cover is the exact same one.
Nov 02, 2012 | Sewing Machines
We have a Fender P-250 PA system. We get the protect light on when we turn on the system rather than the green power light. We can not get it to operate. Please advise... Gary
Likely there is either a failure in one of the power amps or the power supply. The protect means excess current is being sensed.
You need to take in for repair... these are really hard to work on due to the packaging.
Sep 23, 2010 | Fender Pd250 Passport Deluxe 250watt...
Vin number location on a mitsubishi rosa deluxe
drivers side windsheild itll be in the bottom corner stamped on the dashbord
Apr 05, 2009 | Mitsubishi Minivan Cars & Trucks
Dayton kerosene heater 3E219B will not turn on
I have a Dayton Model # 3e219b 150,000 BTU potable heater and it runs fine with the top cover off.But if I put the cover on it will go out is less than a minute and trip the reset.
Jan 31, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Pool & Spa Logo
61 people viewed this question
Top Pool & Spa Experts
john h
David Spradling
David Spradling
rogerpaul3
Level 1 Expert
Are you a Pool and Spa Expert? Answer questions, earn points and help others
