Check your device manager to ensure webcam is recognized. If it is, open it up and update drivers for it. If not, then load the drivers and software supporting the webcam.
Next, check or update the webcam application software. You may want to try another application to test it. If everything is properly loaded and operational, you should soon have the webcam working again.
1st You download Webcam Driver. My webcam doesnt work in tinychat, but works on skype and yahoo etc... After this install the Webcam driver in the system. Installation of Webcam Driver Go to the control panel Click on the System Icon Click on the Hardware Tab Click on the Device Manager s Select the Unknown Device or printer device where yellow Question Marks sign on it. Right click on it and uninstall it. After this go to the top of the device manager and click on scan for hardware changes. Driver installation Wizard start. Brows Your Driver from the Hard Disk and click on next. Driver will be install.
I had the same problem, work around is easy - Power managment option enable powering all USB port at all times. That should bring your webcam back to life again. You thank you me later. ;-) As i mentioned this is just workaround, I solved this problem installing drivers in correct order, so Dell Vostro USA chipset all 5 then i have instaled program called slim drivers and fund good drivers for USB Ports (most recent) then i aplied all crap from windows update. The driver itself for webcam has nothing to with the problem i believe (its all driver from 2006) the problem is more about system percepction of webcam as exyternal device hooked up to usb port thats why power management interfere with it. And last thing if you mess up already with original driver and cannot install it then remove not working driver using device manager. Deatach laptop from power supply remove battery, and try switch it on; hold the button for 30 second up to 1 minute. then plug everything or just power cord switch on windows automatically detect device and will instal the driver from 2006.
1st You download Webcam Driver. My diwnload disc is not working in order for me to After this install the Webcam driver in the system. Installation of Webcam Driver Go to the control panel Click on the System Icon Click on the Hardware Tab Click on the Device Manager s Select the Unknown Device or printer device where yellow Question Marks sign on it. Right click on it and uninstall it. After this go to the top of the device manager and click on scan for hardware changes. Driver installation Wizard start. Brows Your Driver from the Hard Disk and click on next. Driver will be install.
Check the drivers in Device manager to see if everything is in order. As USBs are plug and play they mainly depend on the firmware being up-to-date, so it may be worth your while looking at logitechs site and checking out your webcams driver. It is also worth trying the camera on another computer and try another USB device on your own. This will eliminate general issues with the webcam and your usb ports.
USB problems can be quickly narrowed down by eliminating issues, so if these dont work come back with any extra details
Copy this site and paste it in your browser ADDRESS Bar and hit ENTER;
http://www.free-codecs.com/AMCap_download.htm
to download the Free AMCAP Video Capture Program. AMCap v9.20 AMCap is a small yet fully functional video capture application compatible with Microsoft DirectShow. It is based on the sample AMCap from the Microsoft DirectX 9 SDK. AMCap supports still captures to BMP, JPEG and PNG formats and it remembers your Video Input, Video Standard and Video size settings from previous session. It has some nice features like multi-monitoring support, zooming, aspect ratio and interlacing features. program. AMCap is a small and effective piece of software and definitely worth trying. Hope this will help. Bud
If you use your webcam in different programs it may be still hooked up on one. Try re-booting your webcam software Mine, I just unplug it and plug it back in. As yours is built in - expand the imaging folder in Device Manager - Right click on the webcam text and toggle between 'disable' and 'enable' leaving it disabled for a few seconds - long enough to re-boot.
1st You download Webcam Driver. My webcam wont work on vista After this install the Webcam driver in the system. Installation of Webcam Driver Go to the control panel Click on the System Icon Click on the Hardware Tab Click on the Device Manager s Select the Unknown Device or printer device where yellow Question Marks sign on it. Right click on it and uninstall it. After this go to the top of the device manager and click on scan for hardware changes. Driver installation Wizard start. Brows Your Driver from the Hard Disk and click on next. Driver will be install.
