The manual says it has a y type connection and must be installed by a licences electrician. If your stove already has a y type cord fitted you will need a 3 phase y type socket. If the stove has no cord the a y type one of the correct rating will need to be fitted. This job can lead to danger if not done correctly
A freestanding full function electric cooker requires a dedicated supply fused at 30 amps.
The days when 4.75 mm cable was considered adequate for this are far behind us and these days 6mm or even 10mm is specified though much depends on how far from the consumer unit the cooker point is sited and the routing of the cable; whether under wooden floorboards or clipped to masonry for instance...
Local regulations should be complied with...
