It is either the led backlights or the T-con board.
Testimonial: "seeing others with similar issues it sounds like it could be the connector between power board and LED board. Do you think it is worth resoldering this connector?"
Hi Jimmy,
If I may suggest, before changing, please check that the inverter board is producing the necessary voltage to drive the backlights or not. If the board is producing the necessary power and still the backlight is not coming on, there is possibility that some of the LEDs in the backlight array have failed.
Testimonial: "No matter which HDMI input I use the screen is totally black again. The apple tv works fine on a different Vizio TV with a different HDMI cable."
I would have to guess that the Timing Control Board is defective
This model develops bad solder joints on the connector between the power supply and the led driver board and loses backlighting. It's hard to believe, but the whole connection goes bad. All those pins supply only 24v and gnd. Resolder all of the pins on the power supply half of the connector and the tv will work.
It's the connector between that large yellow board (p/s) and the center green board (led driver).
SOURCE: LG 47LN5750 No picture
If you have backlights its not going to be the tcon for future reference. you have some shorted or open LEDs in the panel. Check the voltage going to the LED sets, should be 100 plus volts
