SOURCE: Need TV codes
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC4700
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you
have one the "magic" button for three seconds, a light should then
flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
SOURCE: I have an One For
Magnavox0020, 0024, 0028, 0030, 0036,
0054, 0096, 0186,
0187, 0230, 0386
These are all the codes listed for magnavox
You didnt say if you knew how to programme
the codes in but let me know if you have any
problems ok
Let me if you have any problems
SOURCE: acces one for all remote
You can go to the link below. enter in your one for all model number then the type of device (TV) then the brand ( Magnavox) then click on Submit
http://www.oneforall-na.com/advanced_search.php
SOURCE: urc-4700B00 tv was given to me,girlfriend don't
It is the remote that needs to have a code entered to recognize your set.
Not knowing if you have the original remote (it shouldn't need a code at all), no one can help you yet.
Also, if you have a remote that didn't come with the set, your chances are slim that your particular set will be among those compatible with the remote.
If that URC number is from the remote, you need to go to this website to find the code list:
Remotes
SOURCE: I have a one for all universal remote URC 4700B00
THIS WEBSITE WORKS FOR ALMOST EVERY UNIVERSAL REMOTE. IF THIS DOESN'T HELP PLEASE LET ME KNOW AND I GET A BETTER SITE. IF THIS DOES HELP CAN YOU PLEASE RATE MY ANSWER
( I GUESS IT IS IMPORTANT FOR THIS SITE)
http://www.xdiv.com/remotes/
