When you performed the power cycle did you make sure all accessories were disconnected?
Also plug the TV directly into a wall mains socket, not through an extension lead or socket!
Repeat this test at least 3 times or until the TV powers up.
Testimonial: "Thanks Mikey; blinking stopped, but now TV is all dead. Only visible sign of life is power on USB port. Tried unlpugging for hours, back in, etc. 5 times. Sounds like end of life for this 8 year old TV..."
SOURCE: please help
That is the blink code for the lamp ballast. Here is the more complicated explanation from the service manual.
IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
then indicates the error when an inner malfunction of LCD Power
C.B.A. occurs, the Lamp voltage becomes more than 130V or
less than 30V, Lamp current becomes more than 5A, or the Lamp is blown
Hope this helps.
SOURCE: Philips 42 in. Plasma shut down
Thank god we purchases the ADVANCED extended warrenty. This tv has been nothing but problems.
Fuzzy picture, picture shutting off after 20 sec coming back on and now blog of colors shut off never to come on again. 7 blinking red lights on the front. Waiting for the repair man again.......
SOURCE: blue power light blinking 3 times
I am having the same problem, what was the solution to this problem? And how much did it cost to fix it?
SOURCE: I have the same problem blue power light blinks 3 times
Ur power board inverter is dead.
U need a new board.
SOURCE: Philips 42PFL3603 tv sound but no picture.
Return it to waranty repair or replacement ur video backlight inverter board is dying going to be dead,than u have no video(picture at all)might just sound.
