Question about Lowrance Boating
How do I stop trolling motor feedback on my bow mounted Lowrance unit?
Posted by Steve Graf on
Attique-ur-Rehman
    Top Expert:
  • Lowrance Master
  • 2,677 Answers
5 Related Answers
Anonymous
SOURCE: Trolling motor will not spin with out being turned by hand.
This may sound really dumb but it's worth a shot. I bought a trolling motor and it did the same thing as yours. I put up with it until I broke a prop blade. When I was changing the prop I discovered about fifty feet of monofilament fishing line wrapped around the shaft, partially melted, hidden by the prop hub. Once removed, it worked fine. Hey, try it, can't hurt.
Posted on Dec 11, 2008
Editor925
Dean
  • 285 Answers
SOURCE: Mounting a sonor/transducer on a MinnKota Riptide ST
Did the unit come with a strap to mount the transducer to a bow mount electric? Most units do... If not there is probably one available for the unit as an aftermarket accessory or accessory from the manufacturer... Regarding the transducer wire, just wrap and rout this up the front of the bow mount motor shaft so when you pull the motor up and secure it, it is not going to get in the way. You could cable tie the cord down near the bottom of the shaft and one up near the top where they wont interfere with the motor bracket when the motor is positioned up on the boat.
Posted on Mar 17, 2009
Obertelli
Obertelli
  • 3006 Answers
SOURCE: do i need a motor mount to attach a 12v trolling
Yes. Any motor installed on an inflatable is going to need something solid to mount onto.
Posted on Jul 04, 2009
Anonymous
SOURCE: lowrance x135 not functioning properly
Had the same issue with another brand. Turned out the transducer cable was picking up noise from other cables (power, trolling mtr. etc). Try moving the transducer cable away from any other cables. I put the cable in a 1/4 " plastic housing up to the point where it was above deck and it stopped all the strange stuff. Not sure about the temp issue??
Posted on Jul 21, 2009
Anonymous
SOURCE: I have a 1999-model Minn-Kota bow-mount trolling
55 is a 12 volt system northland marine has diagram.
Posted on Jan 29, 2010
How do i install elite 5 dsi on 14' tiller boat
Install the battery cables to the battery for the gas motor.
Here is a transducer installation guide for Lowrance, this is pretty standard for all transducers. Pay attention to how the boat sits in the water when trolling for level setting to match in water.
http://primus.lowrance.com/icr/units/HDS%20Installation%20Guide.pdf
If you don't have a PDF reader foxit reader is free.
http://www.foxitsoftware.com/Secure_PDF_Reader/
Apr 13, 2013 | Lowrance Elite-5 DSI Color Combo...
I have a riptide st 80 24 volt bow mount co-pilot. Still under warranty but has worked well for 9 months. When I start unit, it works well for 15 seconds (more/less) and then shuts off with the green on...
Start to look for the charge state of your battery.
Measure the voltage on the battery connectors when the motor falls out. If lower than 11v your battery is too weak.
Also check all the cables between battery and motor. Check foor loose connection or oxidation.
Aug 19, 2017 | Minn Kota Riptide St Saltwater 80 Bow...
Trolling motor doens't work
I have a trolling motor and can't seem to get it to come on. I seen it work when I got the boat. But now it won't come on.
May 06, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
I lost istallation manual for minn kota power drive v2 50# thrust bow mount tolling motor, where can I find instruction manual?
Contact the people at this Email address. Minn Kota <[email protected]> The address is between the brackets. They emailed me a manual for a different trolling motor. They are nice folks. It will take up to a week for you to get a reply.
Apr 22, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Lowrance x135 not functioning properly
Mar 29, 2009 | Lowrance X135 Power Pro Sonar Without...
Mar 17, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
How to install trolling motor
If it is a bow mount model, then you basically need a bow mount bracket attached to the bow of your boat. If one didn't come with the outboard, you will have to buy one from the same manufacturer or an after-market one suitable for your boat. If in doubt, consult the local boating or marine store or wherever you purchased the motor or the bracket from.
Mar 15, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
Transducer is mounted on a plastic bracket to trolling motor. when trolling motor is turned on, black vertical lines appear on my screen. lowrance x107 cdf
Are you utilizing another unit in your dash? If so, sometimes when both units are on and in sonar mode, their frequencies will intefere with each other causing the vertical lines. I would suggest turning your dash unit off or lowering it's Hertz rate from 200Hz down to 50Hz.
Funny story...I saw this same issue on my boat years ago. I had an X102C up fron and an LCX-19c in the dash. I acutally thought it was some sort of man-made structure and spent time fishing it...DOH!
Aug 23, 2008 | Lowrance LMS 332c Mapping Sonar/GPS...
Boating Logo
53 people viewed this question
Top Lowrance Boating Experts
Mike
Marvin
Marvin
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
