Question about Konica Minolta Office Equipment & Supplies
How do I remove error Code F907 on Konica Minolta Bizhub C360?
Posted by Joseph Chacha on
5 Related Answers
Anonymous
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Posted on Nov 19, 2007
herminio_hal
Herminio Halili, Jr.
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
Anonymous
SOURCE: Konica Minolta Bizhub c350 error code c-0510
I have this code
C0510 Upper fusing roller abnormally low temp
how can I replace the thermistor in the fuser
Posted on Dec 30, 2009
hamzaskilltd
amir hamza
  • 318 Answers
SOURCE: Error code C-0211 Konica Minolta Bizhub
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} C0211 :Bypass Lifting Motor Failure
Posted on Aug 07, 2010
inthanhdat
SOURCE: konica minolta Bizhub C6500 error code 2424
Hi, I have a C6500 Bizhub pro, but, recently displays an C2404 error. I need to print an urgent job and y can't!
Please helpme!
Posted on Sep 15, 2011
Error sortout
Conduct the following setting.
[Service Mode] ? [Memory/HDD Adj.] ? [Memory Check]
? [Detail Check].
When "NG" is displayed, replace the appropriate memory or
PWB.
WORK0: DIMM0
WORK1: DIMM1
FILE0,1: MFP board
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sep 28, 2016 | Konica Minolta Bizhub C360
Error solve ?
MFP board (MFPB) not receiving SIO receiving port...ADF ADF (Document feeder) not talking to main board.have tech come out might need to be re-flashed worse case both board need to be replaced
Sep 23, 2016 | Konica Minolta Bizhub C360 Color Copier...
C-F907 bizhub C360 -
sir, MFP board (MFPB) not receiving SIO receiving port...ADF ADF (Document feeder) not talking to main board.have tech come out might need to be re-flashed worse case both board need to be replaced
Sep 22, 2016 | Konica Minolta Bizhub C360
What is error code c5370
appears to be fan error from the rear of the printer. perhaps over heating or not spinning or very dirty
May 11, 2014 | Konica Minolta Bizhub C360...
Konica minolta bizhub c360 cannot stabilize color
what code is showing what do images look like????
Apr 17, 2014 | Konica Minolta Bizhub C360
Bizhub c360 error code 12
l-12 or p-12 code????????????????????????????
Feb 07, 2014 | Konica Minolta Bizhub C360
I have changed the setting of the dev unit of the Konica minolta C360 to No life But it still says replace unit. The printer is still giving excellent prints
it continue to showing this error and u have to press ok
just make prints till print are coming ok
after that u have to change unit
Aug 06, 2013 | Konica Minolta Bizhub C360
PRINTER TROUBLE CODE C-0210 KONICA MINOLTA
on previous models with this code check that there is no paper caught behind the tray open and close door to clear code
Feb 11, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
