SOURCE: kenmore 12 stitch sewing machine-wont sew
repair and parts it's all here just open this link....
all the advantages is here , hustle free, saves time and money ...
www.myrepairmaster.com.
SOURCE: material doesn't move
Are the feed dogs engaged? Janomes usually have a feed dog sliding switch, either on the back of the sewing machine at the bottom, or behind the accessory case. Be sure the check it out. Hope this helps!
SOURCE: needle clamp won't attach to needle bar
There is a set screw above the needle pin screw which tightens with an allen wrench--try that.
SOURCE: tread keeps coming out of the needle.
Make sure you sink the needle into the fabric before starting to sew. If that isn't it...remove the thread and rethread the machine. Make sure the thread isn't wrapped around the spool holder.
SOURCE: I am trying to hem a pair of Lulu Lemon yoga pants
Most likely the pants are a knit or stretchy fabric and you should be using a ballpoint needle especially for knits. Try poking the needles through your fabric and pull them back out just to see if there's a burr on one of them. If not, you can use them if you can't get the ballpoint ones. If the fabric is knit and it keeps getting caught, try putting a stabilizer under the fabric to get it to sew smoothly. You can try a light tearaway from Joanne Fabrics. If you can't get to a store, try waxed paper, tissue paper, an old pattern or anything that you have that can be torn away after you stitch. You only need a strip on the bottom of the hem. If the pattern is intricate and the paper sticks after the tearaway process, you can just dampen the paper so it will fall off. Hope this solves your problem.
Add a Comment [Check the placement of needle, blunt or bend needle can also be the problem. you may also have threaded the machine wrongly
