The bright spot is in the middle of the TV circlish line shaped. I had a technician visit, but without even turning the TV, he saw some smudges of cleaning towel on external part of screen and made a decision it is water damage. It was obvious he was trying to devoid the warranty to not fix it. Please note that the last time I cleaned it with a wet towel was at least 8 months and it is the way the manual recommends to clean the TV. The entire TV is behaving normally, sound is okay, all parts (wifi, sockets...etc) are working fine, so I doubt it is anything in the board, the entire screen is working well also, only the bright part, but no other sides that have blurs, or signs of creeping water. The spot is 1-2 inch in size and it is not completely dead, it shows the image, but brighter.
Sounds like an imperfection in one of the layers of the screen, this can be resolved by dismantling the screen and cleaning the layers in a dust free environment...... so in everyday terms this should be done under warranty.
As for water damage.... unless the patch starts from the outer edge of the screen it is highly unlikely to be caused by water damage in my opinion.
Testimonial: "Thank you so much, you really have no idea how much this helps!"
SOURCE: toshiba 2060 marks on papaer
There is no such paper for copiers that I know of in 18 years. What you can do is try to run some blank pages throw the copier. This can tell 2 things if the line gets lighter in may be in the fixing ***'y and the upper fusing roller is shoot, needs to be replaced and or if it dose not clear up you may need a cleaning blade for the drum(OPC) and or the drum and blade as a set. It depends on how old the parts are? You may need to replace all 3 items and a general cleaning. Here is a idea for you are you running LTR or LTR-R you may be able to switch the paper arould to avoid the line all togather. Good Luck.... You may need a service call on the copier. With the age of the copier I might just go with the cheap fix first.
SOURCE: Grease, or some substance on clean clothes
You need to thouroughly clean the large door seal in all of its grooves and the inside of the door as well. Just put on gloves and use detergent to do this and rags or pape rtowels. Also make sure the inside of the tub is clean and that you are not overfilling the washer. Good luck.
SOURCE: Screen damaged from fall, colored vert lines on left side from the damge
Unfortunately the LCD panel would need to be replaced. Even if there is not any signs of damage to the outside portion of the panel, one of the inner screens may have been fractured. I am not sure if the panel would be available because if i'm not mistaken Sharp just started making replacement panels.
SOURCE: smudge looking marks onscreen
If you suddenly noticed it, this is most likely caused by a large piece of dust on the lens. It is hard to clean, you would need to take the whole TV apart in order to get to the lens (mounted on the optical block).
It could also be caused by a failure of the optical block, which had inherent issues. There is a pending class action law suit against Sony for problems with optical block that include smudges, hazes, and tints that appear after a certain number of hours.
Other causes could be a dirty portion of the mirror or a smudge on the inside part of the screen but these are rare because dust and contaminants do not usually accumulate on these parts of the TV.
