Televison & Video Logo
Ayres Mozzochi Posted on May 07, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am trying to program my Philips TV to this remote and it is not working I cannot find any manuals for this even on the manufacturer's website.
Mikey
Level 3:
Top Expert:
  • Philips Master 6,903 Answers
  • Posted on May 07, 2020
 Mikey
Philips Master
Level 3:
Top Expert:
Answers
6903
Questions
5
Helped
1620209
Points
26101
Do you have a model number for the remote?
5 Related Answers
Anonymous
  • 23 Answers
  • Posted on Jun 26, 2008
SOURCE: remote codes
GE ........... 0704 0312 0018 0002 0502
................. 0006 0007 0601 0835 0901
................. 0114 0103 0803 0806 0310
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
Anonymous
  • 97 Answers
  • Posted on Jul 29, 2008
SOURCE: philips universal tv remote not working
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
Thisis the user's manual for a Phillips remote control. There is a list ofcodes in it. They should be rather universal. There's also instructionsas to how to program it. I believe that there is a way to program itwithout using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.Press the Channel Up button repeatedly (up to 300 times) until thedevice could be controlled changes channel. The red indicator blinks,then stays lit. If you accidentally overshoot the code required, pressthe Channel Down button to backtrack through the library until thedevice changes channel. Pressing Channel Up changes direction toforward again. Press and release the Mute button to install the code.
Hope this helps :)
Anonymous
  • Posted on Nov 13, 2008
SOURCE: i lost my manuals to my philips universal remote how do i program it wthoout using the code
I lost my instructions to program my tv with the remote can you help me
Anonymous
  • Posted on Nov 26, 2008
SOURCE: Help with comcast remote code setup for philips tv
Try adding 1 to the front of the code. 10054 worked for me. Hope this helps.
Anonymous
  • 7 Answers
  • Posted on Mar 29, 2009
SOURCE: Philips Universal Remote PM435S reprogramming
I have the same tv and remote that you do. I went on Philips website and they have instruction manuals and the code lists. You can also press and hold the 'CODE SEARCH' button until the light stays on. Then press 'TV' button. Make sure your TV is on and press Channel Up button until the channel changes on your TV. If you go too far, press the Channel Down button until it changes again. Then press the Mute button to store the code. Good Luck!!
What other brand universesal remote can I use on my black point tv
There are many universal remote brands available that you can use with your Black Point TV. Some popular options include:
  1. RCA Universal Remote
  2. Logitech Harmony Remote
  3. GE Universal Remote
  4. Sony Universal Remote
  5. Philips Universal Remote
When purchasing a universal remote, be sure to check that it is compatible with your Black Point TV. You may also need to program the remote to work with your TV using a specific code. This code can often be found in the remote's manual or on the manufacturer's website.
Looking for remote control code to operate Philips 65PFL4864 TV from Sony BDP-S370's remote (RMT-B107A).
If you're trying to control your Philips 65PFL4864 TV with the remote control of your Sony BDP-S370 Blu-ray player (model RMT-B107A), you will need to find the remote control code that corresponds to your TV.
The codes for different brands and models of TVs can vary depending on the remote control, but you can try using one of the following codes:
  • Code 020
  • Code 021
  • Code 022
  • Code 023
  • Code 024
  • Code 025
  • Code 026
  • Code 027
To use the codes, you need to follow these steps:
  1. Turn on your TV and Blu-ray player
  2. Press and hold the "TV" button on the remote control of your Blu-ray player.
  3. While holding the "TV" button, enter one of the codes listed above.
  4. Release the "TV" button and check if the TV responds to the commands from the remote control.
  5. If the TV does not respond, try the next code in the list.
You should be able to find the instructions on how to program your remote control in the manual of your Blu-ray player. If you don't have the manual, you can download it from the Sony website or contact the manufacturer for assistance.
Keep in mind that these codes are not guaranteed to work, and it's possible that your remote control may not be able to control your TV. In this case, you may need to consider purchasing a universal remote control that is compatible with your TV and Blu-ray player.
2answers
Universal Remote
are you programming the remotes with the codes for the TV manufacturer, as most Universals have to be programmed to the manufacturers remote codes to function, or Most if not all universals have a scan for the code function, refer to the manuals did theTV originally come with a remote, I am assuming so, if it didn't the TV may not have an IR reciever for the remote to work.
If this helps, please give a fixya rating, every one helps
I changed the batteries in my phillips universal remote and when I did it would not work. I have a magnavox tv but I do not have the code or know the steps to fix it
You shouldn't have to do anything after changing the batteries. Philips and Magnavox are the same brand, so the Philips univeral control should work your TV without programming it. Check the batteries and make sure your new ones are in facing the right direction. Also be sure the new batteries are actually good. I've fixed remotes for people by just changing the batteries again, even though the replacements were fresh out of the package. Also, did the old batteries leak in the remote? The battery contacts may have corrosion on them. There's also the chance the TV's remote sensor is at fault. If you can, try the remote with another Magnavox TV or program it for another device and see if it's working, or try another remote with your TV. If you need programming instructions for your remote, you can usually find them on the manufacturer's website.
10helpful
2answers
Philips universal remote control cl034
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1500115_AD_EN.pdf
Try this website it really works. I just tried it today and I am sooo happy.
2helpful
Lost manual
go to the Philips Magnovox website- you should be able to find an online manual
How do i program remote to work tv?
There may be a combination of keys to press to get it into programming mode. This isn't consistent from remote to remote, probably not even if brand is the same. I'd suggest going to the manufacturer's website, and see if they have the manual posted there, for either viewing or printing. Beyond this, your guess is as good as mine.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
