SOURCE: Ilo plasma
Well, it could have been struck by somthing, have you tried unplugging it from your wall and re plugging it in? If so - it may be just flat out dead
SOURCE: WELL???? PDP4210EA hooking up to it?
I was able to find a service manual online which lists the inputs for that TV as the following:
Your Playstation would need to be plugged into either the component or composite connectors depending on which Playstation you have. The Playstation 1, Playstation 2, and Playstation 3 all can use the same composite cable, and the Playstation 2 and Playstation 3 can both use the same component cable. The Playstation 4 only uses HDMI, which your TV doesn't support, so you would need to use an HDMI to component converter (under $20 on Amazon).
As for the Roku, same rules apply, but it again depends on your Roku model.
