Question about Pool & Spa
Hi all i have just purchased a Lay-z-spa and gonna be setting it up was widening i have an extension that the same grade wire as the pump wire, was wondering is it possible to swap the lead on the RCD end to a longer wire?
Posted by michael on
5 Related Answers
Anonymous
SOURCE: lay z spa water pump is faulty where can I get a
Hi Im Chris From BVL Elecric,
I cover Bournemouth and surrounding areas and supply solutions to most home electrical problems.
A lovely lady customer called me out today to diagnose faulty
LAY-Z-SPA
pump/heater that kept tripping the RCD.
After scouring the net and finding this same problem over and over again but no solution,I decided to get personal with the blighter!!!
RESULT:- problem solved,
Customer very happy,
no new parts fitted,
water heating fine now.
If you live in my coverage area,have a LAY-Z-SPA that is faulty,no or limited warranty then give me a ring and I will be only to happy to come on over and fix it for a small fee.
just think that dead spa/pool heater/pump could be heating your water again tomorrow and there is plenty of summer left to enjoy it.
You can find my details quite easily , just google BVL Electric Bournemouth
Posted on Jul 02, 2010
Rinoo Kumari
  • 2973 Answers
SOURCE: Hi, I have a Bestways
If it is tripping the RCD then there could be a short circuit somewhere. or the Heating element is shorted. Please check the wiring and the element.
Posted on Nov 22, 2010
adamh294
adam hudson
  • 310 Answers
SOURCE: lay z spa pump has
If this is an outdoor spa near trees, its almost a guarantee that the impeller is blocked with debris (pine needles can cause this in a hurry)
If the impeller is clean of debris and this is still happening, replace you pressure/flow switch.
Posted on Apr 27, 2011
MOTORWIZJ
Jay Finke
  • 1389 Answers
SOURCE: lay ze spa pump not working atall digital display
HAVE THE MOTOR TESTED. TAKE IT OUT AND PUT POWER TO IT. IT USUALLY IS THE MOTOR, AND NEEDS REPAIR
Posted on Jun 04, 2011
Andy Turner
  • 910 Answers
SOURCE: My bestway lay z spa
PDF Manual at the link below.
http://www.drinkstuff.com/products/pdf/lay-z-spa-owers-manual.pdf
All lights flashing indicate a fault with the pump.
This is a common fault with these units which the supplier blames on people not following the installation and maintenance instructions.
If you require any further assistance then please just ask.
Posted on Aug 01, 2011
Has anyone had problems with Lay Z Spa pumps?
Lots of people have had issues with them. I'm afraid that they don't last particularly long. The Lay Z Spa's are built to a price.
I have delivered a new acrylic spa to someone today who previously had a Lay Z Spa, he had owned it for about 14 months and was already on his second pump unit.
Apr 22, 2017 | Pool & Spa
My Intex pure spa will not turn on just making an noise
im gonna assume that its not the first time you have used it , and maybe have returned to using it from a dorment period, if so this is a common problem with pumps that are not put in storage correctly . to correctly store a pool or spa im gonna suggest a "wet" storage vs a dry type storage , as your just not gonna be able to get all the "material" out of pump since 1st use , to properly store a WET pump some sort of non freezing fluid must be used , I like Rv antifreeze but vegtable oil (both food grade) has been used in good standing as well
the noise you hear is the pump motor trying to turn but the impeller "pump" is frozen by corrsion sometimes a dissasembly and regrease with waterproof grease from hardware store works some times it requires pump replacement due to breakage
Oct 12, 2014 | Pool & Spa
Why is my lay z spa not heating?
if the heat light comes on but doesnt heat bad heater element if red heat light doesnt come on need new temp sensor
Aug 31, 2014 | Pool & Spa
Bestway Lay-Z-Spa
We sell the Bestway Lazy-Spa however we do not sell anything other than the replacement filter so I cannot tell you what is all included with that part number.
I would suggest you contact the store you purchased the spa from to determine the contents of the replacement item.
Rod
US Parts Center
Feb 12, 2014 | Pool & Spa
Leaking lay z spa pump
Firstly try some Fix-a-leak spa leak repair.
If the suspected leak is less than 1/8" that should fix it.
Or remove the paneling to find where it is coming from, there is no easy solution.
Jul 25, 2012 | Pool & Spa
Hi just put our new lay z spa up but the pump wont bleed. There is water round the filter but it doesnt rise up enough to push the air out.
is the pump setting higher that the water in ur spa??? and there should be a pitcock valve to open on ur filter to let air out
Mar 31, 2011 | Garden
Pool pump shutting off/tripping the circuit breaker
What kind of pump are you using?
Sounds like the Intex is restricting water flow there by heating up your pump and shutting it down..
You may need to re plumb everything to handle the flow.
Intex hoses and fittings are different than the industry standards just so the can make you buy from them
Do what ever it takes to get good flow
Jul 01, 2010 | Intex Automatic Salt Water System for ...
Lay z spa water pump is faulty where can I get a
LAY-Z-SPA
Dec 27, 2009 | Pool & Spa
Pool & Spa Logo
52 people viewed this question
Top Pool & Spa Experts
john h
David Spradling
David Spradling
rogerpaul3
Level 1 Expert
Are you a Pool and Spa Expert? Answer questions, earn points and help others
