Question about Brother DCP 130C All-In-One InkJet Printer
Error 50 brother dcp 130 d
I have error unable clean 50 with my brother dcp 130c.plz help as my thesis is on.
Posted by ar_ax on
Anonymous
    New Friend:
On my DCP 130C display appear an errore message "imp. stamp 50". This is an error message in italian language that indicate impossible to print, error 50.
Please, have you some suggestion to resolve this problem?
Thansk in advance
Posted on Nov 08, 2010
John Green
  • 35 Answers
Does the carriage jam moving across the move to home position?
If so try a paper towel and 20 weight oil to clean the carriage and then try again.
Posted on Apr 21, 2015
Unable to print error 50
try to clean the printer from the inside. clean the cartridges and all of the connections that you can find. I wouldn't stat opening the printer, as it may cause further damage which will forfeit your warranty
Oct 15, 2009 | Brother DCP 130C All-In-One InkJet Printer
Unable to clean 46
posted fix in another prob same section
Aug 23, 2008 | Brother DCP 130C All-In-One InkJet Printer
Error 46
did you already fix it? my printer is also dcp 130 c... it says unable to clean 46
thannks
Aug 08, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brotherdcp-130c printer
Brother DCP-130C is not printing and is refering me to the manual which is useless. It also says "Unit unable 43" .
Any help great! Cheers
Jul 26, 2008 | Brother DCP 130C All-In-One InkJet Printer
Unable to clean
unable to clean troubleshooting maintenance user guide
Jun 13, 2008 | Brother DCP 130C All-In-One InkJet Printer
Brother Print Unable 50 Error
No ;-)
The encoder strip switched off the ph and has to be set into place again.
see here how to fix it:
http://www.fixya.com/support/t211210-brother_mfc845cw
(enlarge the browser window to see pics somewhat better)
An advice:
when you have set the encoder strip in pos. again stick some scotch tape on the top of the ph cover where the strip runs thru to prevend the slipping off again on next paper jam ;-)
Mar 29, 2008 | Brother DCP 130C All-In-One InkJet Printer
Clean unable 46 : what does it mean ?
...because you have run the cleaning cycles too much, the waist inktank is fed up! needs replacing. contact brother hotline or try to get one from a service partner which can be found on the brother homepage of your country.
Feb 09, 2008 | Brother DCP-340CW All-In-One InkJet...
DCP-130C Clean Unable
- pull out the AC plug
- put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
- now you are entering the MAINTENANCE mode and "error 46" pops up in the display
- select 8 by using the arrow buttons ,push OK and select 0 and push OK
- 00:00 00:01 OK (the display is showing this message)
- now push the MONO button 25 times until you see PURGE: xxxxx
- Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
- the purge counter indicates now: purge: 00000
- switch off the printer ,switch it on
- ready to print
Jan 27, 2008 | Brother DCP 130C All-In-One InkJet Printer
Hard cleaning on brother dcp 130c
What do you mean by "hard clean"? Plz give some more details... (What is the main prob that you have...)
Oct 26, 2007 | Office Equipment & Supplies
Brother DCP 130C All-In-One InkJet Printer Logo
1,897 people viewed this question
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
