Question about Maytag Refrigerators
Maytag MDB7759SAW On the top tray bin, front of the right side slide mechanism, front piece broke; when U out tray bin falls out. Slide piece is loose after extending bin. Any replacement parts?
Posted by Lyn Swedberg on
5 Related Answers
teknowolf
David Preston
  • 207 Answers
SOURCE: under desk sliding tray won't slide
It sounds like She closed it with it not quite aligned properly.
First try lift up on it a bit while pulling it out some, if it's jammed it may take quite a bit of force. If you have more than one person 1 might lift and the other pull.
If this is tried with no success, you may have to go underneath the desk with a screwdriver and remove one of the sliderails in order to dislodge it. Once loose seperate the sliderails from the mounts and then reattach the mount to the desk. Then insert the rollers into the mount (Holding tray at a 45 deg angle.) Once the rollers are in tilt the tray down and push the tray in to seat it. It should click into place when it catches. It should now be able to slide as normal.
Hope this helps
Dave
Posted on Nov 21, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: I need to replace a door seal, Hotpoint Ultima WF860
Push the top cover to the rear and lift at the same time, then ease the control panel to the right, you will not get control panel off with the top cover in place.
This will then give you access to the front panel scews, located at the top and bottom of the panel. remove the door seal ,and door lock, then lift the front panel away.
Posted on Dec 04, 2008
jackiaria
Jack Iaria
  • 350 Answers
SOURCE: I need to replace parts on my KINDERKRAFT CRIB 'N JUNIOR No 5103
Here is the 800 number for kinderkraft. They have a website but it doesn't appear to be working. 1-800-822-6748
e-mail [email protected]
http://kinderkraft.com/main.htm
I Hope this helps!
Posted on Jan 19, 2009
Anonymous
SOURCE: front slide not working
Take the battery out, you should see two tiny screws. One has come loose and is jamming the slider.
Posted on Jan 26, 2009
Jim Auburn
  • 412 Answers
SOURCE: I bought a used kodak
The KODAK Carousel 650 was manufactured approximately between 1964 and 1971.
Try removing the tray and pressing the cycle button(s) on the side of the projector. Watch the levers in the cut-out on the top of the projector. The lever closest to the rear of the projector should move back & forth (as you actuate the cycle buttons). The lever toward the front of the projector should extend and push forward (front of the projector) when you push the "forward" button, & extend and push toward the rear in reverse. If you are not seeing these levers move as described, then the chances of your projector needing a repair are likely. The good news: parts are still available. The bad news: You will have to find a factory-trained repair dealer to make the repairs for you.
Posted on Nov 04, 2010
ICE FORM AT THE BOTTOM OF THE FREEZER ALL THE TIME, LEAKS OUT ONTO MY HARDWOOD FLOORS AND FORM PUDDLES
Step 1: . Unplug the fridge. You can wait until later but don't forget.
Step 2: Freezer door. It's 4 screws, one in each corner. Just loosen them a few turns - don't take the screws out entirely - it's much easier putting the door back on when the screws are already in place. The door slides up & off.
Step 3: Lower basket. It lifts out, no tools required. Now's a good time to start eating all your ice cream.
Step 4: Upper basket. Remove the 2 screws at the front of the rails, then lift up the rails slightly on each side, to slide the basket forward.
On the plastic pieces at the back sides of the upper basket, push in two tabs with your screwdriver on each piece & pop them up. This will let the upper basket slide out off the rails.
Step 5: Icemaker. Remove the lower screw, then loosen or remove the two screws above the icemaker. Unplug the wire harness where it passes through the rear panel - squeeze the sides of the plug & pull. Lift the icemaker up & out. The water tube will slide out of the guide.
Step 6: Plastic guards.The thermostat guard is the skinny piece to the upper right. Push in (to the right) the tab on the left side in the middle. The guard opens like a door pivoting on the right edge, & pulls out.
The center fan guard has two tabs at the top on each end that push in toward the center, & another tab in the middle at the bottom of the guard that pops up.
Step 7: Freezer panel. Remove the 4 screws in each corner. Push the thermostat back through the slot at the top, & also push the icemaker plug back through its slot.
FAST/HARD WAY: Pull carefully up & out from the top middle edge. Be careful because that sucker is SHARP! The back panel will bend vertically in the middle as you remove it, but it's flexible & will pop back into shape.
SLOW/EASY WAY: If you don't like bending the panel around the drawer slides, you can take off the slides. The metal rails have tabs that push in to release the whole slide assembly, which pulls out forward. You only need to take the rail housings off one side - when you go to remove the rear panel, just pull that side first. To release the upper section (that you already unscrewed in Step 4), left it up, bend in & pull out - the back end has a tab through the freezer wall. The lower plastic slide housing unscrews with 4 screws.
Step 8: Ice Dam. By now you should see the ice problem. Typically the entire evaporator tray is completely iced, along with some of the tubing. MELT IT ALL. Warm water applied with a turkey baster works well. Be careful not to puncture the coils because ... that will ruin your fridge.
Do all the ice melting while the drain is still plugged so it runs out into the freezer floor where you can sponge it up. If the meltwater goes out through the drain hole, it can flood the pan under the fridge - no big deal, just dirtier water & more mess.
The drain hole is near the front of the rear tray in the middle. It's pretty wide (1/2?) & short, only ~2 inches long. It goes straight down into a rubber "duck bill" grommet that's probably plugged up with gunk, that you access from the back of the fridge...
Step 9: Drain grommet. Pull out the fridge so you can access the back side. Remove the screws (6?) around the lower access panel, pop the power cord up & tilt the panel out of the way. The plastic tray under the fan is the evaporator tray - that's where the water SHOULD normally be dripping into & evaporating from.
Behind (technically in front of) the fan, there's a black drain slide into the tray that leads up to your plugged drain. Push the slide aside to see the drain. There's a rubber "duck bill" grommet on the end. Pull it off & clean it - it's no doubt plugged with gunk. Better yet, trim the opening very slightly so the hole is larger - see this site for photos.
Step 10: Put it all back together. Some tips: if you lived hard/fast & didn't remove the rails & rail housing, getting the freezer panel back in place . Make sure you slide the tray rails all the way out before you start trying to put the rear panel back. Bend the panel vertically along the middle so it springs back into place on each side. Again, wear gloves. Once it's in place, don't forget to run the thermostat wire & icemaker tube/plug out.
When you put the the top tray back, make sure it's all the way to the front before you pop the plastic pieces on each side back down, so the gears on each side are aligned in matching grooves. Otherwise your drawer will be crooked & probably won't slide.
Hope this helps. I have a Whirlpool GX2FGDXVY but these steps work on other models too including Maytag etc.
here is the whole exert video of the whole eplanation watch it,(https://youtu.be/lhuBR1sKx7E)or
kingsley
May 12, 2015 | Samsung RS261MDBP - 26 cu. ft. Side by...
Kodak slide tray mechanism
The Carousel 140 Trays were manufactured as "one-timers" - - - that means (unlike the Ektagraphic 80 Slide Tray), there are no adjustments, no replacement parts, and are not designed for re-assembly.... I am sorry to have to tell you that. My recommendation would be to buy a replacement tray (don't worry - - they are cheap) from a dealer who still has 140 trays (try www.vinevalleyimaging.com )
Good Luck!! Jim
Feb 08, 2014 | Kodak Office Equipment & Supplies
Custom cool drawer sliding mechanism broke
Most of the rail slides, when they break apart, cannot be repaired. It would be better to replace the complete assembly.
Aug 18, 2012 | Refrigerators
I have a Spidem Villa machine with the removable mechanism locked in the machine.I have tried to remove it but no success. How to unlock the mechanism?
Remove the dredge drawer. Open the door. On the left side of the brewing unit, and towards the back of the brew group, there is a single screw. Remove the screw. Grab the handle and pull carefully, but firmly with a quick ****. The brew group should come out. There is a piece that remains in the machine. Slide that piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position.
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. (You can insert your key into the hole in the front and twist the key to return the brew unit to the center. Line up the 2 diamonds and it centered) If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit,(it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door and turn on the machine without having the brew group in, but you must have your drip tray and dredge drawer in. Turn the machine on. You will hear the motor turn on and when it stops completely, open the door and remove the tray, now insert the brew group and replace the tray.
Sep 11, 2010 | Saeco Spidem Villa
Ice cube dispenser will only deliver crushed ice
Remove the ice bin, and in the back of the freezer you'll see a square opening with a white plastic piece inside. When you dispense cubed ice this piece lifts up, lifting the long metal rod that runs along the bottom of the ice bin. When that rod lifts it opens the ice flap at the front of bin, allowing cubes to be dispensed. If the flap is not open, the cubes will be ground against the cutters and you will get crushed ice.
Here's what you can do to make it so that you always get cubed ice. Take a wine cork and stand it on end. Using a good knife, I positioned the blade about 1/3 of the diameter from the edge and cut all the way through the length of the cork. Then remove the ice tray.
Now put your finger in the sqaure opening and lift up the white pastic piece. Slide the modified cork under the flap so that it is jammed into the raised position. (This is the position it should be in when you are asking for cubed ice.) Now slide the ice tray back in while using your left hand to push the plastic ice flap at the front of the tray to the left side (again, the position it should be in for delivering cubed ice). Peer under the tray while you're slowly sliding it back in so that you can see if the metal rod connected to that ice flap successfully slides into the square opening at the back. If it can't slide in above the cork-raised plastic piece, you may need to pull the cork back out and trim a little more off it.
This worked for me... I can't get crushed ice anymore, but I've only needed crushed ice once in the 16 months I've lived here so that's not an issue for me.
Apr 02, 2010 | GE GSS20IEP Side by Side Refrigerator
Ice cube are not dipensed only crushed ice
I had the same problem you do - the solenoid that lifts that white plastic piece is dead. But I also rent the place where I live, and it comes with the fridge. It's not likely the landlord will want to deal with this issue since I can still get ice, not considered a necessity, etc. So here's what I did to make it so that I always get cubed ice.
Thye bag broke when taking the pouch out. The
The unit has a slide out drip tray on the right hand side. When the unit has cooled down, pull the tray out, life the item up and see if the bone falls out. If it does not move, use something like a rolling pin, or the cardboard from kitchen paper roll to push it out from the top.
Dec 14, 2009 | Sunbeam Rocket Grill RG12
Button set on cube - only sends out crushed ice
No , the panel is probably ok .
1 ) remove the ice bin
2 ) in the back of the freezer , you'll see a square hole , with a white rectangle piece inside , which you should be able to lift upward , with your finger . If this piece doesn't lift , then it may be corroded with rust , or be bad . When you call for cubes , this piece lifts up and in the process , lifts the long rod , attached to the ice bin . When the rod lifts , it opens the bin flap , allowing cubes to be dispensed . If it does not lift , the cubes will be ground against the cutters , therefore , dispensing crushed ice .
3 ) to access this solenoid which lifts the cube actuator , remove the 3 or 4 screws on the sides of the PANEL , and with the panel removed , you will have access to the solenoid and actuator .
4 ) you can check the solenoid for continuity , voltage ( when arm pressed for cubes) , or possibly a loose wire .
Jul 28, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
I can only get crushed ice, no cubes
This solution will work if you want to avoid replacing the solenoid and are willing to settle for alawys having cubed ice.
Jul 06, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
LG SXS Refrigerator LSC26905 ice maker
I was able to order the ice tray myself and install it in the fridge - it's not hard. I ordered from one of the parts sellers linked to at the LG website, not those listed in other posts here.
Here's how to replace the tray:
You need to remove the tray dumping mechanism to do this.
  1. Remove the ice bin, set it aside (don't forget to deal with the ice melt).
  2. Turn the ice maker off (LG says to unplug the fridge, I didn't).
  3. On the left hand side of the ice tray dumping mechanism there is a screw helping to keep the entire thing suspended from the ceiling of the freezer. Remove that screw- don't worry, the mechanism will stay put for now.
  4. The dumping mechanism can now slide forward- note that you can't completely remove it from the freezer yet, but slide it forward and it will no longer be suspended from the ceiling. Don't let it drop or hang.
  5. You need to disconnect its power supply now. On the left hand side you should see a small bundle of wires coming from the back of the freezer to the dumping mechanism. It connects to the dumping mechanism's set of wires with a pair of white plugs. Pull these plugs apart. You may need to pry the catch on these plugs apart while you pull.
  6. Now you can take the dumping mechanism out of the freezer (and close your freezer).
  7. To remove the ice tray you need to slide the housing that contains the rotating motor out of the housing. This is on the right side of the mechanism. If you have trouble identifying it look at the underside of the entire thing and you'll see a small "test" button. That button is on the motor.
  8. To remove the motor you'll see two catches on the right side- you'll need to pull these catches out without breaking anything. You'll be able to slide the motor down and out when you get it right.
  9. Sliding the motor out lets you get the old ice tray out now. There is probably a set of white wires routed through a little catch on the old ice tray that you'll need to free.
  10. Put the new ice tray back on the motor. You'll need to get the left side secured at the same time you get the motor housing in its catches of the dumping mechanism.
  11. Reroute those white wires back on the new ice tray.
  12. Reconnect the electric wires to the housing.
  13. Slide the entire dumping housing back onto the ceiling of the freezer and screw in on the left side.
That's it. You can press that test button on the underside of the motor. This will dump the tray and immediately refill it with water so you can observe if everything is working.
Jun 03, 2008 | LG LSC26905TT Side by Side Refrigerator
Refrigerators Logo
50 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
