Question about Pool & Spa
I am trying to replace impeller on my intexpure portable spa. Where can I find one
Posted by Carol Cox on
Why No power to pump
Hi this is Tim with Oceantis, the authorized service provider for all of Comfortline Products Spas in the US.
If you have no power to your unit, and have tried multiple outlets and resetting the GFCI Power Cord, the unit needs to be serviced.
If the water pump is not flowing water, but other functions are working properly, you may try to jump-start the water pump impeller, which is a troubleshooting step that may be found on our website under "Tips and Tricks" Should you need a walk through, don't hesitate to call.
Please contact us Toll Free at (855) 772-6269 between the hours of 8:30AM to 5:00PM EST.
Portable Spas Accessories Parts and Chemicals Oceantis Oceantis Cape...
Jun 16, 2014 | Comfort Line Spa 2 Go Portable Spa with...
Remove impeller from Waterway 502n22c
To remove the impeller you first take the front face plate off to expose the impeller. Then isolate the shaft from the motor with a pair of needle nose vise grips and using a pair of channel lock pliers grip the end of the impeller and rotate counter clockwise to un thread it from the shaft. If the shaft seal has been leaking there may be to much corrosion to turn the impeller in which case it needs to be broken off.
May 13, 2013 | Waterway 5HP Executive 56 Frame Spa Pump...
Trying to replace the seal but can't get the impeller out
THE SHAFT " PROTECTOR" ON THESE THREW BOLT MOTOR PUMP IMPELLERS , IS A JOKE. IT RUSTS TO THE SHAFT OF THE MOTOR MAKING IT NEAR TO IMPOSSIBLE TO REMOVE. I HAVE A 75% SUCCESS RATE. I TAKE THE ROTOR OUT OF THE MOTOR AND STICK IT IN THE VISE, THAN I TRY TO GET THE IMPELLER OFF THAT WAY. GOOD THING MOST THE IMPELLERS FOR THESE ARE CHEAP ONLINE. OH AND I CUT OFF THE "SHAFT PROTECTOR" ON NEW IMPELLERS, AND USE NEVER SEIZE .. HEY YOU .. PRIME THAT PUMP WITH WATER AFTER ANY PUMP REPAIR !! NEVR STARVE THE PUMP FOR WATER !!!! .. CLICK ON THE YES IF'N I WAS OF ANY HELP AT ALL ... JAY TOUR LOCAL POOL PUMP REPAIR GUY IN LONGWOOD FLORIDA...FREE TESTING
May 26, 2011 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
Replaced the seal and impellar, now pump is getting hot and turning off? any suggestions
SOUNDS LIKE YOU GOT THE WRONG IMPELLER, THE ONE YOU GOT IS FOR A BIGGER MOTOR.. THESE IMPELLERS CAN BE A PAIN TO ID, OR EVEN FIND .. TRY THE IMPELLER FOR A 1HP. I BET IT WILL WORK JUST FINE .. JAY THE POOL PUMP REPAIR GUY IN LONGWOOD FL ..
Feb 27, 2011 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
Spa n a box 6 person portable hot tub pump cl250-c pump stops working error message OH on display
If the water pump is not circulating water you will want to do a simple procedure called "turning the impeller" You can call 888-997-6366 to be walked through this procedure over the phone.
Feb 26, 2011 | Comfort Line Spa 2 Go Portable Spa with...
Pump seals
The impeller is threaded on to the shaft. The trick is to hold the shaft in order to untread the impeller. The surest method is to disassemble the back of the motor, exposing the opposite end of the shaft. There should be a spot to put a wrench in order to hold the shaft immobile. Then, it's simply a matter of unthreading the shaft. A strap wrench does a great job of holding the impeller without damaging it.
Dec 04, 2008 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Pool & Spa Logo
44 people viewed this question
Top Pool & Spa Experts
john h
David Spradling
David Spradling
rogerpaul3
Level 1 Expert
Are you a Pool and Spa Expert? Answer questions, earn points and help others
