$118 for a new one.
Bernina-Bernette Electronic Circuit Boards,www.drdanessmh ...
www.drdanessmh.com > berninahelectronbds1
Bernina,Used,In Good Working Condition, Tested 6-12-20 with Meter,USA 110V, Front A-Print Circuit Board for Model: 1130, Non-Returnable, Non- Refundable,
BERNINA Sewing Machine Circuit Control Power Board 1130 ...
www.ebay.com > ... > Sewing Machine Accessories
Find many great new & used options and get the best deals for BERNINA Sewing Machine Circuit Control Power Board 1130 Parts Repair 0003337001 at the ...
US$118.00 · In stock
WOULD I GUESS BERNINA IF I HAD ONE
SOURCE: Bernina 1130 needs an S-Board. None available?
Those are repair only parts you would need to take it to a bernina dealer so they can send it off for repair
SOURCE: i want fix circuit board of my bernina 1030
I have found that the bernina machines in this general product range (i.e. with the slide-in processor boards) do tend to suffer from dry-joints, randomly throughout the boards. If you take the double-stack boards out after removing the handwheel-end cover, separate the two boards, carefully and dont loose the plastic spacers on the securing screws. Best thiong is just to go through the board carefully with a magnifying glass, re-soldering any joints that show signs of having 'frozen' when manufactured. Also, carefully clean the two connectors that provide interconnection between the control board and main processor board with a suitable contact cleaner. I also make a point of removing any surplus flux that may still be on the board from manufacture, using the above cleaner. Most symptoms tend to be when the machine randomly swaps between stitches. The rotary controls are special and not commercially available, so if they get 'scratchy', unsolder them first and give them a good spray with contact cleaner to remove any surface contamination on the potentiometer surface. Icant help with a circuit diagram. By the way, if the motor isn't running properly, the problem is on the power supply 'L'-print on the back of the machine - not the main control board. There is an adjuster on the PSU that is used to set the motor speed. Make a note of its position and just try rotating it back-and-forth a few times, again to clean the track, then return it to approx where it was - this might cure the problem. Again, I dont have a circuit diagram of the 'L'-print.
SOURCE: bernina 1130 backstitch is not working
then you need to call the shop that serviced the machine & tell them
about the problem that the machine won't backstitch & see what they
say
Have you tried a new needle? If the old one is bent or damaged, it could be hitting where it shouldn't be. If a new needle doesn't take care of the problem, you will probably need to take it for service again. Since it was just done, they may not charge a lot for a follow up.
