Question about Hayward Pool & Spa
Where can I buy new wiring for Hayward pump capacitor? My wiring is burned.
Posted by Tonya Miller on
4 Related Answers
poolyoda
  • 128 Answers
SOURCE: Need wiring diagram for Hayward dual Super 2 speed
You need 4 wires to wire the 2 speed pump. You will also need a 2 speed time clock.. Tightwatt or intermatic. The wiring diagram is on the motor.
Posted on Aug 30, 2009
MOTORWIZJ
Jay Finke
  • 1389 Answers
SOURCE: I have a Hayward 1 HP pool pump. I have to
hi ...the two yellow go on one side of the cap and the red /white go on the other.. like two on the negative side of a battery and one on the pos .. your pool pump repair guy longwood fl
Posted on Apr 07, 2010
john224
John Prohaska
  • 1378 Answers
SOURCE: Hayward SP2807X10 Pump Motor doesn't
Thank you for posting your question here on Fixya.com.
It could be the pump is bound up or the bearings seized but it is more likely the motor is failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage. If you wish to continue to try to repair it yourself please comment with any questions you have as you work thru the pump and motor.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Dec 03, 2010
john224
John Prohaska
  • 1378 Answers
SOURCE: I need a wiring diagram to hook my capacitor back
There should be three wires. Two of them will be the same color and the third is usually white & red. The two like-colored wires go together on one pole of the capacitor. The red/white goes by itself on the other. It does not matter white pole is which wire(s), as long as you pair the wires as described.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Posted on Aug 31, 2011
Hayward heating pump won't ignite.
if new and wired for 120 voltage reverse black and white wires if reversed they wont show rectafication if old heater replace or clean up flame sensor
Sep 21, 2014 | Hayward H - Series 400 Heater Top for In -...
HAYWARD HEAT PUMP POOL HEATER FAN WON'T SPIN
if your meaning the top mounted fan , if the compressor does run , and the top fan does not , fans do go bad there not too expensive and don't require a rocket scientist with a truck load of tools to replace them , two biggest things to look for are Height of fan away from hitting solid object (compressor) and match wires color for color (turn power off !!!) , replace capacitor as well they aren't included with motors there extra !!! new motors do say on package what size capacitor to buy (it might be different than old one?)
Jul 31, 2013 | Hayward 116k BTU HeatPro Digital Heat Pump...
Hi my 3/4 hp 230/115 centurian is buzzing and i smell burnt electrics.....what do i need to order to fix?
If the motor can be turned easily by hand then sometimes the starting or run capacitor can be replaced with the same value device and the pump will run. If a new capacitor is installed and it doesn't run then the motor needs to be replaced. If the motor does not turn easily then usually the bearings are bad and the motor needs to be replaced. I hope this helps. The burned smell is either overheated wiring in the motor or a bad capacitor, etc.
Aug 05, 2011 | AO Smith Pool Pump Motor Hayward Swimming...
I have a hayward super ii pump model sp1615z1 that wont start I replace the capacitor because it wasn't working when the timer turn it on.After replacing the capacitor the pump worked fine for a...
There is no cheap fix for a burned up motor...you'll need to replace it. You can replace just the motor for about half the cost of a whole new unit. When you replace the motor you should replace the pump seal as well. Your motor number should be UST1152 for the 1.5 HP and the seal number a 201.
John
Jun 27, 2011 | Hayward SP3015EEAZ Super II Pump 15Horse...
The capacitor is burned and i think thas the problem why the pumps doest'n star
Is there power to the pump or is a breaker being tripped? Find out where, exactly, the power is out. It could be loose wiring in the conduit or a loose connection where it wires into the motor. Many things.
www.cpo2go.com
Dec 02, 2010 | Hayward 1.5hp Max Flo Inground Pool Pump #...
Hayward super ii wont start when cold
If this only happens when it is cold it is probally just a start capacitor. If you open the back of the motor it will be a black cilinder abount two inches by an inch around with two or three wires coming from it. Remove this noting where the wires hook up. I pool store or motor shop will have a new capacitor for you, but you have to bring the old one to match up. Replacing this should solve this problem for you.
Oct 24, 2010 | Hayward 3/4hp Super Pump Inground Pool...
My pool pump is humming then turns off
If the armature will rotate freely and the bearings are not frozen, then it's probably a bad start capacitor. They are not very expensive compared to a new motor so it might be worth replacing it to see if it's bad.
Sep 08, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
Pool & Spa Logo
44 people viewed this question
Top Hayward Pool & Spa Experts
john h
Marvin
Marvin
Paul Carew
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
