The humming noise and non-functioning fans in your Sunquest Pro 24RS tanning bed could be caused by several factors. Here are a few things you can check to diagnose the problem and potential solutions:
Check the power source: Make sure the tanning bed is properly plugged in and the outlet is providing sufficient power. Test the outlet with another device to confirm it is working properly.
Check the circuit breaker: Check the circuit breaker for the tanning bed to ensure it is not tripped or in the off position. If it is tripped, reset it and try turning the tanning bed on again.
Check the wiring: Check the wiring connections inside the tanning bed to ensure they are properly connected and not damaged.
Check the fans: The humming noise and non-functioning fans may be caused by a malfunction in the fan motor or the fan blades may be obstructed. Check the fans for any obstructions and test the fan motor with a multimeter to see if it is receiving power.
Call a professional: If you are unable to diagnose and repair the issue on your own, it is best to call a professional technician to service the tanning bed. They will have the necessary tools and expertise to identify and fix the issue.
In any case, it is important to exercise caution when attempting to diagnose and repair electrical equipment. Always unplug the tanning bed before attempting any repairs and do not attempt any repairs if you are unsure of what you are doing.
Based on the symptoms you have described, it's possible that there may be an issue with the ballast or the lamp in your Sunquest Pro 24 tanning bed.
Here are some steps you can take to troubleshoot the issue:
Check the power source: Ensure that the tanning bed is plugged into a working electrical outlet and that the outlet is supplying the correct voltage. You can use a voltage tester to check the voltage.
Check the ballast: The ballast is a device that regulates the electrical current to the lamp. If the ballast is faulty, it may prevent the lamp from lighting up. Check the ballast for any visible damage or loose connections. If you're comfortable with electronics, you can also use a multimeter to check the ballast's continuity.
Check the lamp: If the ballast is functioning correctly, the issue may be with the lamp. Check the lamp for any visible damage or dark spots. You can also use a continuity tester to check the lamp's continuity.
Check the timer: If the timer is not functioning correctly, it may prevent the tanning bed from turning on or lighting up. Check the timer for any damage or loose connections.
If you're unable to identify the issue, it's best to contact a qualified technician or the manufacturer's customer service for further assistance. Tanning beds use high-voltage electrical components that can be dangerous if mishandled, so it's important to take proper precautions and not attempt to repair the tanning bed yourself unless you're experienced with electronics.
Have a trained technician to look at it. You probably have a loose wire nut in the wall box if it is hardwired or a loose connection on the wall receptical. The screws on the recepticals can come loose when pushing the receptical into the wall box. Most new construction uses plastic wall boxes so shorting out the receptical screws to the box should not be a problem. It is possible that the bare ground wire inside the box is hitting one of the receptical screws. If so, then push the bare wire away from the screws with an insulated screwdriver.
Question is not clear. What kind of device is the combo device replacing? Are you replacing outlet with new combo device? Why does the combo device already have 2 black wires?
Here's what we need to know to answer your question correctly without guessing. Add a comment and say what kind of device is being replaced with combo device. Say exactly what wires are on old device and what color screw wire is connected to.
Say what the outlet is doing. Say what color screws that each wire is connected to on outlet.
Screw color is key to understanding where you are. Each wire that you have now connects to a certain screw color, and we need to know that information to give you professional answer.
