Question about Sony Televison & Video
My Sony xbr43x800D tv has green and orange flashing lights, no picture
Posted by melissa mcneill on
    Top Expert:
  • Sony Master
  • 76,582 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
View the site by desktop or webview on mobile devices to see the "search box". Type in the brand name of your set in search box; to get gathered the related posts.
Posted on May 04, 2020
Testimonial: "This was really helpful, although I am a bit confused. I replaced both the power board and the main board, which led to the alternating flashing lights (green/orange) that appear to be constant rather than in a series with a pause. Would a firmware update via usb solve the problem? Before replacing the power board the tv did not turn on at all so I then replaced the main board as well and the flashing lights are now the result."
5 Related Answers
puggy666
  • 48 Answers
SOURCE: Sony KF-50WE610 LCD projection TV. no picture but flashing green
Replace the lamp as they dont last for long
Posted on Feb 01, 2008
Anonymous
  • 59 Answers
SOURCE: Flashing green light, then green light stays on with no picture
the lamp woul be my first guess
Posted on Jul 31, 2008
Anonymous
  • 203 Answers
SOURCE: Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Posted on Sep 14, 2008
Anonymous
SOURCE: TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Anonymous
  • 320 Answers
SOURCE: Sony KDF-E50A10
Replace the lamp, sounds like a weak or old lamp. Use an original Sony, the replacement lamps are unreliable
Posted on Oct 18, 2008
How to get a picture on sony FULL HD 1080
Hi. Not shore of this model but could be a bulb replacement is needed, Or one of the filter covers may not be making contact.
The red light is indicative of error rather than working ( green ) or standby ( orange ).
I hope you get it sorted.
Sep 12, 2014 | Sony XL5200 LAMP - TV KDS-50A2000,...
Tim Nolan
Sep 14, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Orange light flashes on when turn on Olympus c-50 zoom camera and orange and green lights in upper left corner blink when try to take pictures. Won't take any pictures
The flashing Orange light means the charge is flashing.
The flashing Green light means the focus and exposure are not correct.
Have you recently replaced the batteries? Or are you using rechargeable batteries? Lack of enough "Juice" could allow for the flash to not charge up (Orange) therefore not allowing the camera to get the correct exposure (Green). I would try new fresh batteries or a new battery pack. If that doesn't fix the issue it must be a bad circuitry in the body that is shorting not letting the flash charge.
Regards,
Jacob
Mar 05, 2011 | Olympus Camedia C-50 Zoom Digital Camera
I have Sony Wega and the picture just cut out and went to black. The sound wont come on and the TV wont even turn on. The light at the bottom of the TV flashes lamp light. We took the lamp light out and...
if u take out the lamp the green light will flash ,its not detecting a lamp at all.a bad lamp is being detected before you took it out.u will have to replace the lamp before u get a picture again
Sep 30, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Wavy lines green and orange hue.While watching a fooball game the status bar is wavy and in two separate lines-Green and Orange-Tried flash focus and convergence and powered unit off for several minutes...
Flash focus button push,didn't solved pictures convergence problems.The tv convergence board is dead.The 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 18, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Sony grand wega turns off & o ever 30sec flashes green light
it's a power failure.try to replace the regulator in power supply board.
Sep 04, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Orange/amber light
the orange lamp is suposed to be on when the set is off but there is still power to the set
red will be on when in standby
green when set is on and working
Dec 19, 2008 | Sony Grand WEGA KF-42SX300 42" LCD TV
Open Questions:
Televison & Video Logo
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
