If the transformer is still in the mixer you should be able to trace out the primary by using an ohm meter or continuity tester. connect the meter to one side of the power connector and probe the leads on the transformer til you get a hit mark that wire and continue until you get another hit and that is the other primary.
You don't need any drivers. Laptops and desktops use an internal win device driver. You can actually find the file called keyboard.sys
What you need in your case in a new keyboard. For your Travelmate they sell for about $50. It takes maybe 10 minutes to change it out. This is something you can do at home. Look on you tube for something like laptop keyboard replace and you can see the process and decide if it is something worth trying. If you google or bing or whatever for travelmate 2410 keyboard or laptop parts you can find several dozen sources. If you look they will have instructions or videos for your travelmate.
Yes you can use the equalizer without an amplifier. That is what the high level speaker inputs are for. You simply take the positive and negative from a speaker and hook it up to the positive and negative high level speaker inputs on the equalizer.
equalizer easy to connect and operate-------. line out from mixer to equalizer in------equalizer out to amplifier in. make all control to middle position and adjust the tone of music very slowly and until you find the fine music for you.
The microphone input goes through the same equalization path as input 2: determined by blowing on the mike and hearing a change in speaker sound with changing high band EQ
The remote turn-on wire for an amplifier connects to a switched power source. If the head unit has a power antenna lead, or amp control lead, use it. If not, the remote lead can go to a power source that is switched with the ignition key. No matter the source, you need to fuse the wire with a 1 amp fuse at the point where you connect to the power source.
