I have a Harwa LED Tv model:HW32L1 32inch. It powers on ok but the display is black. I can only see the pictures if I might the screen with a torch on the screen and also if I am too close to the screen. It plays well it's jst that its dim. I set the brightness to 100 but still I does not show. What can I do?
Posted by Stephans Obakeng... on
David Spradling
    Top Expert:
  • Televison & ... Master
  • 11,272 Answers
Check input or source if ok check picture settings
Posted on May 23, 2020
5 Related Answers
Vista Electronics
  • 1694 Answers
SOURCE: screen too dark even with all brightness settings set to max
Try turning up screen voltage with control on transformer....
one is for more brightness and one is for focus.......T.
Posted on Dec 11, 2007
Anonymous
SOURCE: kogi lcd monitor L5BX
check the amp. settings on the power input.
Posted on Mar 23, 2008
Hauleywood
Max G
  • 9 Answers
SOURCE: dim picture
If decide to do yourself, ya only have to do the green and blue ones, the red light spectrum won't allow fungal growth. Pull whole CRT assembly out to prevent spilled/leaking glycol from onto lower main boards
Posted on Jul 05, 2008
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: Acer Aspire 5735 LCD changes bight-dim-bright, etc.
You could have a faulty inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Posted on Jun 25, 2009
Anonymous
SOURCE: Dim screen on DMC FX8 - won't resolve with resets etc.
We had same problem with this camera at work - like another poster has commented, we unscrewed the back casing, lifted it and put it together again - lit up again good as new! must be a faulty connection somewhere. Hopefully it's a permanent fix.
Posted on Oct 29, 2009
Black screen no sound on my TV please help
Hi. Does the TV stay on I.e standby light stays on OK.
if so try shining a torch into the screen while the TVs on see if you see any picture .if so possibly backlight issue.
. What's your make and model number
Feb 03, 2017 | Televison & Video
How do I fix a flat screen tv that when turned on the screen is black with no picture?
place a turned on torch against the tv screen while tv on can you see a picture ? If yes then back light problem possibly inverter that powers the back light.
You tubesearch on tv faults for more insight on possible causes of black screen or no screen on Tv's
if no picture with torch then it might be main board .
Check you tube for ideas on possible causes.
Jan 27, 2017 | Televison & Video
Samsung LED UA40F6400 suddenly lost picture.
The tcon board or the LCD panel is faulty. You have to replace the TCON board to confim the fault.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Aug 06, 2016 | Samsung 40 Inch UA40F6400 Full HD 3D Smart...
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
Screen goes black but sound is good.
This sounds like the inverter which powers the display fluorescent has or is failed/failing. If you take a torch to the blacked out display can you see the image faintly? If so the unit needs repairing.
Mar 12, 2015 | Televison & Video
Lcd tv troubleshooting
Check for power supply trouble. The green LED on the front panel should light if power is getting to your TV. The "no signal" indication may mean no antenna or cable input is detected
Aug 21, 2013 | Televison & Video
Rca L42phd37yx8 42' led tv blackscreen with sound wont show anything
Show a torch light on the screen (not too close) when the TV and program is running. If you can see the picture, the backlights have gone off. Anyhow, the TV needs attention by a qualified service technician.
Jul 13, 2012 | RCA Televison & Video
Harwa tv childlock code
For Harwa (also branded Logik) 54cm colour TV with remote RC-A07 showing blue screen with red lock in the corner, hold down "music" button on remote for 10 seconds to unlock.
Oct 24, 2008 | RCA TruFlat 27F520T 27" TV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
