Question about Aiwa Audio Players & Recorders
SOURCE: fixing aiwa stereo
i have an aiwa stereo system model no: cx- za20k ,the twin cassette deck works fine,but there is no playback from the c d player,the stereo takes 3 cd s and the player just says reading and changes to the next cd endlessly any one help please
Posted on Mar 26, 2009
SOURCE: Dead Battery equals Stereo lock
If you have the original documents (owners manual that came with the car) there should be a anti- theft "code" with instructions for unlocking the radio. If you can't find this info from the factory owners manual - you have to go to the Audi dealer for the fix
Posted on May 27, 2009
SOURCE: Stereo Says Safe and Can't listen to it
Get the code from your dealer with the car's VIN if the system is OEM.
Chances are the code is somewhere in the owners manual package that came with your car....so much for theft proofing...if you or the PO haven't removed it.
If you have the code, like 0095, you press and hold two buttons on the RHS of the Bose Symphoney II, the PSCAN and RBDS buttons IIRC for about 3-5 seconds...the SAFE should go out and 0000 appear on the screen.
You then use the first four program buttons to cycle each number (1 for first 0, 2 for second 0, etc.) to the program code. When you've entered the program code, press the PSCAN and RBDS buttons again to start the radio. I don't think the ignition has to be on.
Next time use a battery jumper...I prefer the portable kind that can be recharged through the power socket/lighter. I just replaced my battery ($153 genuine Audi OEM vice $300 installed) and had no issues with the radio. BTW, the auto up on the drivers and passenger windows probably has to be reset. Lower the window(s) all the way, raise them up and HOLD the switch up for 3 seconds...the auto up will reset.
Posted on Jul 04, 2009
SOURCE: My Blaupunkt, Heidelberg CD51 car stereo beeps
That normally means that it requires the security code to be entered.
Disconnect the fuse for 10 minutes, replace then enter the code.
If you do not have the code then the radio will have to be removed from the dashboard and quote all the letters+numbers on any labels, barcodes or stamped in the metal casing.
Also quote the make of car it is fitted into.
Posted on Sep 02, 2009
SOURCE: AIWA CXNMT 520 CD/TAPE/RADIO PLAYER
Click Aiwa Support to download required user manual for CX-NMT520 (NSX-MT520) that has all info about this sound system.
Thanks.
Posted on Dec 18, 2009
Testimonial: "Extreamly fast and accurate responce that was dead -on in finding owners manual for aiwa player."
Feb 23, 2014 | walmartstores.com Computers & Internet
Feb 02, 2011 | Aiwa CSD-TD901 Cassette/CD Boombox
Dec 09, 2010 | RCA 100-Watt Stereo System With 5-CD...
Feb 27, 2018 | Aiwa CDC-X504MP CD Player
Dec 30, 2009 | Car Audio & Video
Oct 04, 2009 | Audio Players & Recorders
Jul 13, 2009 | Aiwa Audio Players & Recorders
Oct 30, 2008 | Audio Players & Recorders
Dec 25, 2007 | Aiwa Audio Players & Recorders
73 people viewed this question
