Question about Shop Vac Vacuums
If the motor housing is all plastic and there is no metal the user could contact and potentially receive an electric shock from should a fault occur, the ground conductor if fitted, would be connected to the frame of the motor.
Posted on May 03, 2020
SOURCE: after i cleaned the filter, shop vac doesn't turn back on
IT SOUND LIKE THE MOTOR WENT BAD OR IN SIDE THE PANLE A WIRE CAME LOSE
Posted on May 04, 2008
SOURCE: burned out motor on QPL625 Shop Vac
well if you can find the motor ( find a place that deals with the manufacturer directly so you get the right part ) and it isnt to expensive, most shop vacs are pretty easy, if you look under the top you should see about four screws, remove those and the top should come of giving you access to the motor, take note about the wires and what they hook up to. i doubt the motor is fastend down other than that.
Posted on Sep 18, 2008
SOURCE: DEWALT DW795 Vac filters
IT looks like the part number is 429704-56 and the Dewalt site shows list price being $51.68. You should be able to order that filter at a DeWalt dealer in your area, hopefully for a discount.
Otherwise, there is here online:
http://www.ereplacementparts.com/search_result.php?osCsid=2c10ce07c62a161bca9f80f981bf690f
Posted on Feb 26, 2009
SOURCE: Can't install a bag for my Craftsman 16 gallon shop-vac
Well, good news, you don't need a bag! The trash just settles to the bottom of the bucket and you just dump it out.
I own one of these -- it has many little operational anoyances -- like wheels falling off, lid popping off, etc. If you run into these scenarios and want help on fixes, drop me a line.
Would you please rate my response. I think you'll see some icons at the bottom of the post to enter a rating.
thanks...
Charlie
Posted on May 09, 2009
SOURCE: how do you change the ridgid 9 gallon wet/dry shop
all you have to do is open it up and take the paper filter off and then it's a wet vac. If it has a foam over filter you leave that on
Posted on Oct 14, 2009
Jun 04, 2018 | Shop Vac Vacuums
Jan 08, 2016 | Shop Vac Vacuums
Apr 27, 2015 | Craftsman Vacuums
Jun 25, 2014 | Shop-Vac Products 5-gallon 2 0-peak Hp Wet...
Jun 18, 2010 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Feb 22, 2010 | Vacuums
May 09, 2009 | Shop Vac Vacuums
Dec 28, 2008 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Oct 02, 2008 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
May 04, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Jul 26, 2019 | Shop Vac Vacuums
Dec 15, 2018 | Shop Vac Vacuums
56 people viewed this question
